JeffL
- My Cars: 71 Roadrunner
Post
by JeffL » Tue Nov 17, 2015 10:03 pm
- My Cars: 71 GTX
72 cuda repli-mod
Post
by 71_bronze_gtx » Wed Nov 18, 2015 2:26 pm
Might help if you state what year and trim level, but that looks wrong to me. Maybe an A or E body seat? They were less plush. A-body probably narrower. E-bodies in general were as wide as B-bodies, but can't say for certain about the seat. Mine is away at winter storage.
I think not only should it be wider, it should also sit up higher.
JeffL
Post
by JeffL » Wed Nov 18, 2015 2:33 pm
1971 Roadrunner M6XW Trim - Opt. Decor Group, Vinyl Bucket Seats, Black/White TX9: Black Int. Door Frames, C16: Console w/Woodgrain Panel
rradar71
Post
by rradar71 » Wed Nov 18, 2015 3:40 pm
I was wondering if the panels are the right ones as well.
- My Cars: 71 GTX
72 cuda repli-mod
Post
by 71_bronze_gtx » Wed Nov 18, 2015 4:29 pm
Pictures from the Dealer's Guidebook suggest that those are not Roadrunner upper panels. Look like Satellite Sebring.
Did I miss something ? - Black/White - why is the seat blue?
rradar71
Post
by rradar71 » Wed Nov 18, 2015 4:43 pm
SSP panels. Satellite looked alike. Are those re-pops.
- My Cars: 71 GTX
72 cuda repli-mod
Post
by 71_bronze_gtx » Wed Nov 18, 2015 6:30 pm
According to the dealer guide, which I realize isn't necessarily gospel, the GTX and SSP had the woodgrain on the upper panels. The GTX I can vouch for. See the attached. The third pic is the back seat of a 71 SSP survivor I almost bought a while back.
The black rectangular areas surrounded by what appears to be silver or stainless on the white panels pictured look like the front door trim shown for Sebring. Unfortunately, they don't show the rear seats and panels.
![71_Satellite_10 reduced.jpg (295.38 KiB) Viewed 14991 times 71_Satellite_10 reduced.jpg](./download/file.php?id=3785&t=1&sid=7d39a344f9de9f0e636a728083594fd4)
![71_Satellite_12reduced.jpg (253.53 KiB) Viewed 14991 times 71_Satellite_12reduced.jpg](./download/file.php?id=3786&t=1&sid=7d39a344f9de9f0e636a728083594fd4)
![P3060028reduced.jpg (540.12 KiB) Viewed 14991 times P3060028reduced.jpg](./download/file.php?id=3787&t=1&sid=7d39a344f9de9f0e636a728083594fd4)
rradar71
Post
by rradar71 » Wed Nov 18, 2015 7:08 pm
The top portion is not the issue. My Sebring lower part was the same as the SSP. What I was talking about was how the bottom appears to have been cut or it was made that way. I think that it should extend down next to the seat instead of even with the top of the seat.
JeffL
Post
by JeffL » Wed Nov 18, 2015 8:59 pm
rradar71
Post
by rradar71 » Wed Nov 18, 2015 9:23 pm
By the time you get carpeting under there and center the seat a little, it should close the gap between the seat and the lower panel.
Post
by 71bird » Wed Nov 18, 2015 9:57 pm
From what I see I think that the one side panel is just warped, because it should be pushed up against the seat. Also, the upper panel is a Road Runner deluxe panel, but the seats are the standard cheap seat cover covers. I'd try finding a different side panel to see if it helps.My seat doesn't have that part in the rear that looks like a cut out.
- My Cars: 71 GTX
72 cuda repli-mod
Post
by 71_bronze_gtx » Wed Nov 18, 2015 10:34 pm
Attaching a pic of a lower panel out of my GTX. Looks about the same as yours.
These plastic panels are made of ABS, which is highly resistant to warping unless exposed to extremely high temps.
The seat bottom you have is too narrow, which is highlighted by the photos. The seat back fits correctly against the trim panels. Maybe the bottom is a poorly done recover, missing some padding on the sides?
![DSCF2176reduced.jpg (576.51 KiB) Viewed 14968 times DSCF2176reduced.jpg](./download/file.php?id=3788&t=1&sid=7d39a344f9de9f0e636a728083594fd4)
moparmarks
Post
by moparmarks » Sat Dec 05, 2015 10:24 pm
Those are 71 RR with Decor interior upper panels.
moparmarks on Sat Dec 05, 2015 10:50 pm, edited 1 time in total.
Southwestern Sheet Metal
71-4 B-body
moparmarks
Post
by moparmarks » Sat Dec 05, 2015 10:29 pm
Also those are Challenger seat covers and probably the frames are too so that's probably the problem.
71-4 B-body
moparmarks
Post
by moparmarks » Sat Dec 05, 2015 10:32 pm
Here are the RR Decor seats.
![DCP_8100.jpg (165.57 KiB) Viewed 14870 times DCP_8100.jpg](./download/file.php?id=3791&t=1&sid=7d39a344f9de9f0e636a728083594fd4)
71-4 B-body
