so far i have finally got the engine completed
too many parts to list everything other than the pistons and crank and timing chain cover have been replaced and i mean everything
also found that all the bearings were shot in the diff and it was just killing the unit,so again apart from the 3,91s and the case [489 case] everything was replaced even put a new tail on it even a dana style locker in there,also new green bearings were installed on the half shafts
i ripped apart the gearbox and installed the recon kit put it back together chucked some paint on [some drips that need sorting] and walla
everything apart from the engine was caked in grim gease and oil to give you an idea i also stripped down and repainted the rear end the match the diff.i have new shocks a new steering box and new steering componants yet to instal also have to take the Kmember out to weld a bit of chassis while that is out i shall give that a bit of work and paint him silver all the suspension componants etc will be painted white
