k changemember
- My Cars: 71 roadrunner project
74 ssp parting
k changemember
hey guys , great site , question : will a 74 ssp k member fit under a 71 roadrunner , will gain disc brakes and power steering . or wud it be easier to change that over individualy. will have some project pics after xmas
74 ssp parting
Re: k changemember
i guess i shud say , is it a bolt up or do i need a welder , cutting torch and a john deere cultivator for material ?
Re: k changemember
No NO NO NO, These cars are totally different, Actually if you have drum brakes on a 71 you can buy a conversion kit, some only about 700 dollars to convert to disc. I have a 72 and the rotors alone now cost 350 dollars a pair!!! It would be cheaper for me to covert a drum brake car than to rebuild my factory disc brakes!! The conversions are much larger brakes too..
74 ssp parting
Re: k changemember
r you saying the satilitte is different then the roadrunner or they changed from 71 to74?
Re: k changemember
71-72 b-body dodge or plymouth 2door 4 door sw are same charger road runner gtx
73 74 b-body dodge or plymouth 2door 4 door sw are same charger road runner gtx
you can not use a 73-74 k member in 71-72
- moparmodeler
Re: k changemember
In 1973 the front suspensions changed on all Mopars. So no, it will not work, It would be costly and a waste of time to try.
You can use 71- 72 Charger k-Member.
There are many options you can do. Be patient and research all options for the one that best suits you.
74 ssp parting
Re: k changemember
it just so happens that i have a wrecked 72 and a 74 charger too. do the rotos off the 74s fit the 72?
- moparmodeler
Re: k changemember
No they do not! Nothing is the same.71 fj6 wrote:it just so happens that i have a wrecked 72 and a 74 charger too. do the rotos off the 74s fit the 72?
74 ssp parting
Re: k changemember
thank you very much for the info and please excuse me for all the dumb questions , i m kicking around a bunch of options . again thanks for your patience
- moparmodeler
Re: k changemember
You ask very good questions, I don't think they ars dumb at all. In fact I have asked the very same queastion myself!!
Re: k changemember
You can actually swap over the 73-up spindles,rotors,caliper brackets,calipers onto the 71.Use the 71 control arms and ball joints.You also have to change the master cylinder and the proportioning valve.But it is a cheap conversion.
Its not numbers matching
It doesn't run on pump gas
11.73 at 115mph
11.73 at 115mph
