update
strokerblue72
My Cars: 1972 plymouth roadrunner
update
Post by strokerblue72 » Sun Aug 22, 2010 3:53 pm
I know i havent come on for a very long time but i have to travel almost 100 miles a day to work so not much time for internet
so far i have finally got the engine completed
too many parts to list everything other than the pistons and crank and timing chain cover have been replaced and i mean everything
also found that all the bearings were shot in the diff and it was just killing the unit,so again apart from the 3,91s and the case [489 case] everything was replaced even put a new tail on it even a dana style locker in there,also new green bearings were installed on the half shafts
i ripped apart the gearbox and installed the recon kit put it back together chucked some paint on [some drips that need sorting] and walla
everything apart from the engine was caked in grim gease and oil to give you an idea i also stripped down and repainted the rear end the match the diff.i have new shocks a new steering box and new steering componants yet to instal also have to take the Kmember out to weld a bit of chassis while that is out i shall give that a bit of work and paint him silver all the suspension componants etc will be painted white
Re: update
Post by rr6pak » Sun Aug 22, 2010 4:07 pm
Keep us posted... 8)
strokerblue72
Re: update
Post by strokerblue72 » Sun Aug 22, 2010 4:08 pm
Just to give you an idea this is the gearbox obviously just after i got it out,this was about the cleanest thing on the car and it took hours with the scrubber and degreaser
72Satellite440
Re: update
Post by 72Satellite440 » Sun Aug 22, 2010 10:20 pm
Looks great soo far man :) keep up the awsome work
72-SaTeLliTe440-Dan
strokerblue72
Re: update
Post by strokerblue72 » Mon Aug 23, 2010 9:51 am
i have just fineshd with the filler on the wing a hole 3 inch wide by about 2 high,
Next year i am hoping to either replace or have the wings acid dipped along with the inners and the doors i shall then leave the front end in primer untill i can get the new rear quarters floor pans and boot floor.
I am trying to keep him on the road as much as possible while im doing this,although he has been off the road 1 year and 1 month already
