Molding clip studs
wejewill
My Cars: 1972 rm23 with GY8 color, D13 three on the floor, with a 440 4bbl, 323 gears, made in St. Louis plant LOVE IT!
Molding clip studs
Post by wejewill » Sat May 03, 2014 11:15 am
Good Morning,
I need to know what to do about the little studs that hold the molding clips in place. I have new rear quarters and those little studs did not come with the new metal? Do I need to put those back in place or can I attach the window moldings without the clips?
Thanks,
Jeff
kenny
My Cars: RM23N1G107875
Re: Molding clip studs
Post by kenny » Sat May 03, 2014 10:38 pm
you will need the clips if you want to put the trim back on and have it fit good. however you don't need to try and reuse the studs from the old quarters, they make some screws you can use to attach the clips, you will want get the measurements from your old stud locations and place the screws in the same location.
wejewill
Post by wejewill » Sat May 03, 2014 11:06 pm
Thanks so much for the information. Do you know who sells the screws?
kenny
Post by kenny » Sat May 03, 2014 11:57 pm
i got mine from the local auto body supply store, it was a small sheet metal screw with a fairly large diameter head for its size and the head was pretty flat, so it would not get to far into the window channel i guess.
wejewill
Post by wejewill » Fri May 09, 2014 6:12 pm
Thanks! Kenny I will go to the local guy and ask.
