Weatehrstripping
Weatehrstripping
Year 1 only sells a standard kit to replace side-glass weatherstripping. They also say it is not good for show quality. Anybody know where I can get the correct pieces for my ' 72 RR.
Also, their headliner is not corect, according to them. Any advice on that?
Thanks !
Thanks !
- ajcpaperboy
- My Cars: '71 Road Runner
Go to the endorsed vendors forum.I believe you will find what you are looking for there.
Hey roelbest,
I got all my weatherstripping from the Paddock, the brand is Soft Seal.
I looks pretty good I think, dunno if there are any better versions available.
If you are getting new window felt strips, you need to talk to AZ-Nick, he's got what you need. There's a thread on this subject still running on this forum.
Capsule
Capsule
As far as I know, no one is reproducing CORRECT quarter glass weatherstripping (the one that goes between the door and quarter windows). The originals had a metal core for strength while repros are all rubber....unless Nick has other cool new repops I was not aware of.
Are you talking about the Quarter Window Vertical Seals?Capsule wrote:Eric,
the weather strip between the door and quater glass that I got from the Paddock does have a steel core and its almost 100% identical to the original ones. I can't recall the manufacturer, I'll see if I saved the packaging.
Capsule
Unless Paddock has changed suppliers and has not updated there website, there product comes from one of my many manufactures that I sell products from. I can say for sure that there rubber strips come with a small piece (very thin) of metal running down one side of it. I have a few in different years in stock and I just looked at them tonight. There website still lists the manufactures part number that I also use when I purchase them from the manufacture.
71 GTX 4sp GY9
70 R/T Challenger - 80's look
I got mine from GT Restoration in San Bernadino, CA
Checking my receipts, I bought them 4/19/2004 for $33.30/pr plus $7.00 shipping. Item # MB 1855-80
Only real issue I had was not with the seals but with the little and VERY fragile metal tab that is a part of the chrome attached to the window. It goes through a small slot on the seals and then is bent down to hold them in place. When I bent it UP, naturally it broke off.
Turns out to not be a big deal as the seals are a very tight fit to slide into the channel on the chrome piece attached to the front of the quarter window.
I don't remember if the seals had a metal spine in them, but I'm pretty sure they did as they were very stiff.
Re: Quarter Window Vertical Seals
Yep, part number MB 1855-80 comes from another supplier I carry, it to has the small thin spine in it just like you said.72Rdrnner wrote:I got mine from GT Restoration in San Bernadino, CA
Here is a picture of one, I took a close up of it and you can just see the metal strip in it.
71 GTX 4sp GY9
I think many companies like the Paddock get a lot of their rubber products for a company called Steele Rubber Products. I went right to the source themselves and got their seals especially the ones you guys are talking about for the quarter window. Mine were very factory correct. You can get a huge free catalog from them. http://166.82.96.3/homeframes.html
Hope this helps.
Hope this helps.
