Vibration
- aerodynamic
Vibration
Hey guys,
My 400 has a fairly noticeable harmonic engine vibration. It's worse on the highway and makes driving it there really uncomfortable. Is it possible it has the wrong balancer? I seem to recall seeing liquid filled balancers available at one time, anyone know about these? I had another one of these cars years ago with a 440 and that one vibrated too. Anyone else run into this?
Thx for any help.
Greg
Thx for any help.
Greg
73 Road Runner 400 auto
- aerodynamic
- 72GY9Runner
Could be a possible Torque Converter issue too.
If you have a cast crank converter on a steel crank, or the other way around. Or just a bad internally damaged converter.
If you have a cast crank there should be 2 large weights on the converter. The steel crank version varies a bit. Usually no weight, or a really small one.
Something I was unaware of until I got my Runner. I had always thought that all 400's were cast crank, but there was a 400HP version in 72 that used steel. So... it pays to check closely.
Dave Lutz
- aerodynamic
Yes, that thought had crossed my mind too. I have a rear main seal starting to leak, so maybe I'll use the opportunity to examine the converter as well. Anything's possible on this car, after all the last owner put a huge amp in the trunk but neglected to fuse the power feed wire, which melted itself to the underside of the old carpet and fried quite a few wires under the dash. He also filled the A-pillar rust holes under the vinyl with plumbing foam. This car deserved better (and got it, thankfully).
71
72 74 400 4bbl 4speed are steel crank
72 -74 400 atuo are cast crank
- 72GY9Runner
Are we sure only 4 speeds got the steel crank?
The friend who sold me my Runner has a yellow factory auto with 400 and the air grabber and it was a steel crank car as well. Anyone else know of steel crank auto cars?
Mine is one now.
Mine is one now.
Dave Lutz
Shown above is damper #3614374, used on 400's with external balance cast cranks, /or automatic trans application 400 4bbl or 2 bbl(applications with 400 engines manual transmission applications used forged cranks.) I
3614371 72-75 std forged
