Post
by road chicken » Fri Jul 28, 2006 2:36 pm
There were only two CFM ratings for TQs that I know of. 850 and 1000. The 850 works just fine because the secondaries only feed as much air as the engine needs. So even though it is rated at 850- if the engine only need 725, that is all the TQ will give it.
Oh BTW, my carb is an 850 cfm not 750- holley spread bore..
Just for an Idea it uses #62 jets in the primary side, and #85's in the secondary. So staying out of the secondaries, yo can see it isn't being fed a huge amount. Plus the velocity of the A/F charge helps things too.
