Steering wheel adapter
Need some help guys, trying to install a Grant Tuff repop on my 71 that came with the standard wheel, is this the adapter I need?, this seems to be an OEM piece, does nobody make an aftermarket adapter, Grant tech knows nothing, as does Classic Industries, this seems it would be a very common item...confused.Thanks for help.
						Re: Steering wheel adapter
Sure looks right. Viewing it from the side does it have indentations in it similar to a coffee can? If so, that's the one! Just got a Tuff wheel for my Runner too. Am waiting to get the adapter and horn button from a friend. Since upgrading to the Firm Feel steering unit I'm looking forward to having a wheel with a little more "beef" to it rather than the skinny old THIN standard wheel in mine...
Here are a couple photos of my original tuff wheel/adapter. Not sure if the grant uses the same or not.
Hmmm, so was it the earlier ones that had the "ridges" in them?
						- road chicken
No, the ones that look like a bellows were for the cuda/ challengers.bruce wrote:Hmmm, so was it the earlier ones that had the "ridges" in them?
road chicken wrote:No, the ones that look like a bellows were for the cuda/ challengers.bruce wrote:Hmmm, so was it the earlier ones that had the "ridges" in them?
Gotcha! Guess I've seen more of those than I have ones for B-bodies.
				gcoupe72
Yep, the E body one is also longer, puts the wheel too close to your chest in my opinion.
I found a tuff wheel (in dark blue) in an early 80s Cordoba. Same adapter, I believe.
Don't overlook late 70s and early 80s cars, B,R,F,M,J, bodies all could have them and I think I've seen them in Li'l Red Trucks too!
Leave no stone unturned in your search
Thanks men, sounds like I'm on the right track, if they were put on that many years, should be a ton out there, going to Carlisle, probably find a table stacked with them....
Be prepared for sticker shock on tuff wheel adapters. Prices have shot way up on them. Probably looking at $100 for a decent one.morty318 wrote:Thanks men, sounds like I'm on the right track, if they were put on that many years, should be a ton out there, going to Carlisle, probably find a table stacked with them....
				gcoupe72
Hopefully you'll score at a U-Pull-It yard.
Mine, with the wheel, was waaaaay less
 - My Cars: 71 Satellite
Hello fellas.  I seem to be missing as spade terminal and wire on my Tuff wheel adaptor.  Does anyone have a close up of the electrical connections for these wheels?  Also, where there different center caps for different car lines?  Mine is black plastic with a silver painted recessed groove around the perimeter.
