74 road runner factory towing capacity
74 Roadrunner
anyone know what these were rated at? with the factory hitch and extra leaf spring.
Road Runner trailer towing "but why?"
From page 70 of glove box owners manual
" the Manufacture's Customer Care Warranty will apply to cars used to tow trailers for non-commercial use, but if the loaded trailer weight exceeds 2,000 pounds, the following condition must be met:
(1) Equip the vehicle with a factory installed Trailer Towing Package (or equivalent equpiment)
(2) if the loaded tongue weight exceeds 200 pounds, equip the vehicle with a properly installed frame-type load equalizing hitch:
(3) in addition to the normal maintenace services, (a) change transmission oil and filter and adjust transmission bands every 24,000 miles and (b) change rear axle lubricant every 36,000 miles or 3 years (whichever occurs first);
(4) Loaded trailer weight must not exceed 4,000 pounds.
I guess #2000 as is and #4000 with Tow Package which is usually heavy duty radiator, tranny cooler, heavier shocks and or rear springs. Just not sure in 71, even an oiler cooler may be part of a Tow package.
Now why would you tow with a RR?
Good Luck
Chris
Good Luck
Chris
74 Roadrunner
74 Roadrunner
727 needs a tranny cooler
If you have a 727 AT you will need a tranny cooler. Fried a tranny in a Chevy van I used to tow my boat. Now I have a tow package in my Ford van to tow with a Tranny cooler.
If you row the gears you'll be OK.
74 Roadrunner
