Checked the new coil, while turning the motor it does not spark, except for a small spark as I stop turning the motor. Next step was to check the ballast resistor, it is also new. By touching the terminal with a tester, the upper right shows a very weak glow, the other 3 terminal lights up more bright. Changed the resistor and coil with the old ones, no difference.
Is the next step to change the electronic ignition unit? I am still using the original one, as it is '72.
I have made sure that the earth straps are good.
All the wiring looms are new, plugleads, coil etc all new.
I'll appreciate any input, I am in a bit of a remote spot on this island to get help with a car.
thanks
