Which RR Nest members have the latest car birthdays 71-74?
- My Cars: 1971 ssp-rr / not a clone 2 vin plates Y39 SPECIAL ORDER
Re: Which RR Nest members have the latest car birthdays 71-7
I worked for Chrylers for 33 yrs. number 2 1968 RR,,,number 2, 1970 Cuda,, number 17, 1971 RR,, DATE HIRE 9-1-1964...
mike donovan
And a roadrunner clone
mikedonovan wrote:1971 ssp/rr.... 101115 just found. 383 original miles, documented by Gavin govier. Interesting story. rp23/ rm23, 2 vin plates, special order
2 vin plates.....Where on the car are they.
Larry
1971 drag car
1972 440 6pack Roadrunner
1971 drag car
- 71ChallengerSE
1971 Dodge Demon 'Sizzler'
Moparlar wrote:mikedonovan wrote:1971 ssp/rr.... 101115 just found. 383 original miles, documented by Gavin govier. Interesting story. rp23/ rm23, 2 vin plates, special order
Larry
Need pics
Please tell us the story!!!!!!!!!!!!!!!
BTW how could you order a SSP and a RR in the same car?
Are you saying you built a car on the assembly line with all RR or GTX goodies and then at the end you put a RP23 or RH23 tag on it.
Mine was June 20 (fender tag and line 1, "order number" first 3 digits) and according to what I've been told, line 6 "time" block says 0953 and that's when the car was "complete" although I can't verify that.
On the Monroney sticker, under the "S.O. NO." is "65207" and "63" whatever the hell that means.
My '71 RS was built Sept 17/70
'71 GTX N96
Actually an early build GTX. I checked the other post for early birthdays and Streetwedg's GTX was built a few weeks earlier.NOrrTH wrote:My '71 RS was built Sept 17/70
my 73 rr/GTX is 3/08/73 is that late or early ?
March is about 3/4 the way through the production year, so late but not super late. But you are the first 73RR/GTX so I will get you on the list. Thanks!rav440 wrote:my 73 rr/GTX is 3/08/73 is that late or early ?
- mopar71
- My Cars: 1971 roadrunner
that line on my 71 fender tag reads 902.sdweatherman wrote:Called the build date or service production date (spd) it is on your fender tag. Usually second line from the bottom and 4th group over. It is a 3 digit group. 1st digit is the month, 1-9 for Jan-Sep and A-C for Oct-Dec. The next two for the date of that month. It should be on the broadcast sheet, can anyone verify that?
For a 1971 vehicle, that equates to a build date of September 2nd, 1970. Scott.mopar71 wrote:that line on my 71 fender tag reads 902.sdweatherman wrote:Called the build date or service production date (spd) it is on your fender tag. Usually second line from the bottom and 4th group over. It is a 3 digit group. 1st digit is the month, 1-9 for Jan-Sep and A-C for Oct-Dec. The next two for the date of that month. It should be on the broadcast sheet, can anyone verify that?
- mopar71
so is that pretty late?
That's fairly early...start of production for 71 B bodies was the first week of August 70mopar71 wrote:so is that pretty late?
- My Cars: 1973 Satty RL21M3G
Former 400, now 440 powered.
My 73 has 803 on the fender tag. So, is that Aug 3? Is that early, or late?
Like Eric said - 71 production started in Aug of 1970 - so your build date is roughly one month into the production year. The sequence number on your VIN should follow suit. They started with 100001 for the first car built that year - My car was built on Aug 26th with a sequence number of 1069xx - so given the trend of about 350 cars per day - and your car being built on Sep 2nd - the last 6 numbers in your vin should be somewheres close to 109000. Am I in the ballpark?Eric wrote:That's fairly early...start of production for 71 B bodies was the first week of August 70mopar71 wrote:so is that pretty late?
