ball joints
steved
other stuff
ball joints
Post by steved » Thu Jul 22, 2010 8:55 pm
front upper ball joints are stuck....dang...
quapman
Re: ball joints
Post by quapman » Fri Jul 23, 2010 7:58 am
Stuck how, exactly?
ajcpaperboy
My Cars: '71 Road Runner
Re: ball joints
Post by ajcpaperboy » Fri Jul 23, 2010 12:01 pm
Do you need a big hammer?
Re: ball joints
Post by 471Magnum » Fri Jul 23, 2010 12:18 pm
3 foot breaker bar and 4 foot cheater pipe... plus some liquid wrench. Works every time.
steved
other stuff
Re: ball joints
Post by steved » Sun Jul 25, 2010 11:18 am
The joints are just stuck in there super tight. I'm going to try a bigger impact, probably with a little heat.
quapman
Re: ball joints
Post by quapman » Sun Jul 25, 2010 11:27 am
If a pickle fork doesn't work, whack the spindle sideways where the joint goes through. This shocks and deforms the tapered "bond" just enough to let it go.
Re: ball joints
Post by 471Magnum » Sun Jul 25, 2010 11:31 am
steved wrote:The joints are just stuck in there super tight. I'm going to try a bigger impact, probably with a little heat.
Impact isn't going to get it done. They require massive torque which means breaker bar and cheater pipe.
steved
other stuff
Re: ball joints
Post by steved » Sun Jul 25, 2010 6:36 pm
update: got them.
I ended up at my buddy's shop where we used heat AND the 3/4 drive impact. The impact is one of the big mammajammas meant for indycar pitlane duty.
we tried a 4' pipe on the end of the breaker, no dice with two of us on it.
quapman
Re: ball joints
Post by quapman » Sun Jul 25, 2010 8:52 pm
Ahhh, you're unscrewing the joint itself from the UCA. Never mind my tips, you're way past that!
