Project heater box, gross!
TX9GTXN96
Post by TX9GTXN96 » Fri Oct 02, 2009 11:38 am
After I started to pull the heater box apart, I found this little surprise :shock: He was quite mummified!
Peek a boo! (look in the blower wheel)
(120.25 KiB) Downloaded 3168 times
My Mopars:
TX9GTXN96
Re: Project heater box, gross!
Post by TX9GTXN96 » Fri Oct 02, 2009 11:39 am
Yuck!
(97.75 KiB) Downloaded 3164 times
My Mopars:
TX9GTXN96
Post by TX9GTXN96 » Fri Oct 02, 2009 11:41 am
He certainly tried to get out, note the bite marks on the plastic wheel! Poor little critter :cry:
(65.86 KiB) Downloaded 3160 times
My Mopars:
TX9GTXN96
Post by TX9GTXN96 » Fri Oct 02, 2009 11:43 am
This is where he probably lived before tragedy struck :o Wonder if there was ever another Broadcast sheet copy in there?
(115.86 KiB) Downloaded 3157 times
My Mopars:
steved
other stuff
Post by steved » Fri Oct 02, 2009 4:16 pm
mine had a rat nest and a big ol' snakeskin...
TX9GTXN96
Post by TX9GTXN96 » Sat Oct 03, 2009 12:24 pm
Smart snake, easy hunting!
My Mopars:
steved
other stuff
Post by steved » Tue Oct 27, 2009 8:12 am
My GTX has A/C. I found that O'Reilly has a heater core for 49.99 (cheaper than my rad shop could fix it). I'll be picking it up today. The A/C condenser is getting a lookover at the local radiator shop, they're also dipping the gas tank.
I think when I put the halves of the heater box back together, i'm going to RTV the joint. the lower edge had this ultra thick tar like stuff just covering the bottom seam...I think it was a bandaid to keep the interior dry.
TX9GTXN96
Post by TX9GTXN96 » Wed Oct 28, 2009 3:43 pm
steved- do yourself a HUGE favor and buy the heater/ac box restoration gasket and seal kit from this guy
http://www.restorick.com/products.asp?cat=9
My Mopars:
steved
other stuff
A/C cars are different
Post by steved » Thu Oct 29, 2009 8:18 am
I've got an A/C car. unless it's the same as the E-body set...
I wrote him about the set, and he's only got A/C B-bodies up to '70. the E-body kit looks good, but isn't the same.
Post by 72RoadRunnerGTX » Thu Oct 29, 2009 3:45 pm
Need a gasket set for 71-74’ b-body A/C housing? Jim over at Detroit Muscle Technolgies makes them.
Highly recommend, I used quite a few of his gasket sets on my 72' RR/GTX project.
Last edited by 72RoadRunnerGTX on Thu Oct 29, 2009 4:12 pm, edited 1 time in total.
steved
other stuff
Post by steved » Thu Oct 29, 2009 4:05 pm
Funny...I just ordered from them around noon.
I'm going to go back for their firewall and exterior seal sets...
