need pics of one-piece kickdown linkage hooked-up
Post by landon1 » Sun Aug 30, 2009 5:36 pm
so, my kickdown linkage hasn't been hooked-up right apparently the whole time i've owned the car (who knew - car seemed fine)...anyhow, need pics of your big blocks with one-piece kickdown rods :beer:
Ronnman
Re: need pics of one-piece kickdown linkage hooked-up
Post by Ronnman » Sun Aug 30, 2009 8:21 pm
See kickdown pic
Ron
(127.68 KiB) Downloaded 927 times
Post by landon1 » Sun Aug 30, 2009 10:25 pm
RIGHT ON! just what i needed - i searched everywhere for a picture or even a factory diagram - i found one diagram, but it wasn't purty....i like the look of the silver on the kickdown rod - i may have to re-paint mine since i did it engine color :wink:
Post by landon1 » Mon Aug 31, 2009 12:05 am
dang it! looked at a pic of mine and my linkage is a little different from yours - maybe cuz yours is a B block and mine's an RB? the piece that connects to the throttle on the carb is flat on yours but is bent to make it in far enough to meet the carb...now where should i hook the spring i just ordered? lol
i guess maybe drill a hole in that piece so that it lines up with the throttle lever extension and hope the spring isn't too long, or maybe modify it a lil bit :?
Post by landon1 » Mon Aug 31, 2009 12:42 am
answered my own question maybe....seem to be getting pretty good at that lately 8) anyhow, guess i'll have to break down and spend the $15 on a throttle extension bracket deal - never had one before, but i reckon i better do it "right" even though it was working before :lol:
Ronnman
Post by Ronnman » Mon Aug 31, 2009 7:34 pm
See attached pic of a 440 challenger I once owned. It had a later model block, I think a 76, that the previous owner installed. The pic shows the type of kickdown level that is on your engine. I believe this kickdown rod is from a later model like a late 70's version. Anyway, I had to use some aluminum tubing sections to space the flat rod so it stayed in line. It work perfectly.
Ron
(441.5 KiB) Downloaded 872 times
Post by landon1 » Mon Aug 31, 2009 8:35 pm
that's a little closer...note how i don't have a "flat piece" it is bent inward to make a squared-off"S" kind of...maybe i'll have to flatten out my piece that's bent and re-drill it so that it's adjusted properly...more to come on this predicament :?
72RDRNR
My Cars: 1972 Roadrunner
Post by 72RDRNR » Tue Sep 01, 2009 12:30 pm
Mine is same as Ron's. I can bring it by for you in next couple of days if you would like. Mine is from the 400 that was originally in my car but it works fine for 440. I did find a good shop that rechecked and made minor change to my final adjustment for me and didn't even charge me. Great guy and a fellow Mopar fan!
Post by landon1 » Wed Sep 02, 2009 1:00 am
might have to take you up on that :beer: after the whole missing oil galley plug fiasco, i finally got the motor re-assembled and re-primed this evening/night. lot of work, roughly 5 hours, but everything is done, except for replacing my rear accelerator pump diaphragm, mounting the carb/hooking up fuel line, putting in driver's spark plugs/connecting wires. other than that, everything is done. way too tired to be dealing with a carb and fuel right now :lol: should be getting my throttle extension and kickdown spring in the next couple days - goal is to have it at my dad's house by this weekend to start re-wirng, mounting new mirror, and other miscellaneous things
