74-72 steering
74-72 steering
hoping mabey someone could answer a ?. ive got a non pwer steering gear box and colum out of a 74 rr and i want to put it in place of the power st. unit in my 72 sat. is this a direct swap if i use both the colum and the gearbox? thanks,jeff
Re: 74-72 steering
the 71-72 are not same as 73 -74
you have find one from 71-72 why do you want to switch it from power steering to manual?
Re: 74-72 steering
what is the difference that keeps it from working if i switch both the gear box and the colum? i want to switch to clean up the engine compartment .the car is no where near stock so originality isnt important. thanks,jeff
Re: 74-72 steering
the difference may be because the front suspension is different on the 73-4 cars, so a column and box from a 71-2 is going to be the only option.
Re: 74-72 steering
i will have a 71 one went i go from manual to power steering
