One more thing we won't be able to do on our cars anymore
Post by Eric » Fri Mar 14, 2008 6:43 pm
I just got this in an e-newsletter I receive.....haven't done any fact checking yet, but if it's true, this is just one more thing we won't be able to do on our own daily drivers anymore :mad: ....pretty soon I won't even be able to wash my own vehicle!!!
The Ruling
NHTSA have stipulated that by 2008 all US cars will be fitted with TPMS systems most of which use 'direct' sensors which are either part of the valve stem or banded to the wheel. These transmit their own ID along with their pressure, temperature and other data to the vehicle ECU. Every time you need to rotate tires or replace a faulty sensor then the ECU needs to be reprogrammed with the new IDs and their position on the vehicle.
Under section 13 of the Transportation Recall Enhancement, Accountability, and Documentation (TREAD) Act, the Secretary of Transportation was required to complete a rulemaking for a regulation mandating a warning system in each new motor vehicle to indicate to the operator when a tire is significantly under-inflated.
Accordingly, the accompanying final rule requires a tire pressure monitoring system (TPMS) to be installed in all new passenger cars, multipurpose passenger vehicles, trucks, and buses that have a gross vehicle weight rating (GVWR) of 4,536 kg (10,000 lbs.) or less, except those vehicles with dual wheels on an axle. The final rule requires that the driver be given a warning when tire pressure is 25 percent or more below the vehicle manufacturer’s recommended cold tire inflation pressure (placard pressure) for one to four tires. (We note that the agency had previously issued a final rule providing two different compliance options with different levels of stringency. However, a court decision1 found that the TREAD Act requires a TPMS with a four-tire detection capability, so the court vacated the standard for further rulemaking consistent with its opinion.) The final rule also requires a TPMS malfunction indicator, as well as a warning when the system detects under-inflation of 25 percent or more in one to four tires.
moparbrian
Post by moparbrian » Fri Mar 14, 2008 7:00 pm
My landcruiser already has this.
DeLorean00
Post by DeLorean00 » Fri Mar 14, 2008 7:41 pm
So does my BMW
fourforty6pac
Post by fourforty6pac » Fri Mar 14, 2008 10:29 pm
My Titan has it.
patrick
Post by patrick » Sat Mar 15, 2008 1:24 am
Who cares if your old car doesn't have it? It says mandatory regulation for NEW cars, not mandatory retrofitting for old. Or did I miss something? So does this go for motorcycles too? Heard they're gonna start smogging 2009 and later models. Lame, lame...
100% Death Proof
Post by Eric » Sat Mar 15, 2008 1:35 am
Yes, new cars.
From the responses, maybe I'm the only one who thinks this is just more stupid government regulation! I for one still rotate my own tires on my daily driver. Guess that will change with the next vehicle I buy. Also, I like to put aftermarket rims on.....I'm sure this will drive the price of them WAY UP.
Post by Smellslike1974 » Sat Mar 15, 2008 9:40 am
thats just pathetic,why do they insist on changing the stuff that doesnt need changing?
patrick
Post by patrick » Sat Mar 15, 2008 4:58 pm
1) Because they can make money off of it
2) It's the "blame McDonald's for me being fat" mentality of America, and since people are generally too stupid to check their tire pressures regularly, they die and the government has to step in
3) See #1
100% Death Proof
Serious Satellite
Post by Serious Satellite » Sat Mar 15, 2008 11:37 pm
patrick wrote:1) Because they can make money off of it
3) See #1
I blame my wife for me being fat. . .she can't cook worth a crap and I had to go to McDonalds. . .so it's her fault!
Actually, I do think Big Brother has gotten a bit out of control. We're taxed to the point that the refund they're giving us to stimulate the economy is going to be taxable as income. So they're taxing our taxes. . .
:cry: :mad:
Post by mopar71 » Sun Mar 16, 2008 11:59 am
:haha:
Can we say "Taxation without representation", our forfathers are rolling over in their graves, remember what the boston tea party was about! :mad:
