PG Classic Air Grabber Kit
So how complete is this kit?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 37989&rd=1
Is there anything else I'd need other than a hood and vacuum can?
Anybody got a Satellite hood they want to sell, or trade (within a resonable radius of Evansville, IN) towards a GTX/RR standard hood?
- rr6pak
- My Cars: 1971 Tor-Red RR
air grabber
This kit is complete...everything you need..
Re: PG Classic Air Grabber Kit
I wish I had a satellite hood to trade you.. I would do it in a heartbeat. Seems like if you can you should save the original hood just incase. Just a thought.471Magnum wrote: Anybody got a Satellite hood they want to sell, or trade (within a resonable radius of Evansville, IN) towards a GTX/RR standard hood?
- ajcpaperboy
- My Cars: '71 Road Runner
- fourforty6pac
You need all the fasteners the ones for the bubble, hard to find and pricey. You need the fasteners that hold the oval seal to the box. The seal that goes around the door and the pair for the sides of the door. You also need a switch bracket and a bezel. Oh! and the decals.I know there are a couple more smaller parts I'm forgetting, like the air cleaner. You will have to spend close to $500 more to get it done right. There's nothing like an Air Grabber! I didn't see a hinge either, so add a bit more.
71 air
1970-72 340, 383, 400 and 440 4-Barrel with fresh-air hood for B-body. 383 and 400 baseplates are different and sit higher on the carb than the others.
the 440 one is hard one
to fine
Re: 71 air
I've actually got a 6 BBL set up, but with the non-AG base.71440 gtx wrote:1970-72 340, 383, 400 and 440 4-Barrel with fresh-air hood for B-body. 383 and 400 baseplates are different and sit higher on the carb than the others.
The AG is a long term project. I'm just putting a shopping list together at this point.
Re: 71 air
471Magnum wrote:I've actually got a 6 BBL set up, but with the non-AG base.71440 gtx wrote:1970-72 340, 383, 400 and 440 4-Barrel with fresh-air hood for B-body. 383 and 400 baseplates are different and sit higher on the carb than the others.
so you have a 69 1/2 base ? 70 71 6bbl base will fit a ac car 70 -72
ihave 69 440 4bbl base fo my 71 gtx
Re: 71 air
This is what I've got.71440 gtx wrote:so you have a 69 1/2 base ? 70 71 6bbl base will fit a ac car 70 -72
Re: 71 air
Yup, that's the non air grabber base. The ones for a fresh air hood didn't have the shield on the front.471Magnum wrote:This is what I've got.71440 gtx wrote:so you have a 69 1/2 base ? 70 71 6bbl base will fit a ac car 70 -72
Yeah, thats the non-fresh air one, but it will still work in an air grabber, I've seen lots of them that have the wrong one, but they still work.
This is a parts list provided to me by a friend. I need to compare it to the PG Classic kit.
- Air grabber conversion:
Hood
hood bubble
hood bubble door
door hinge
bottom of hood air box
air box seal
air box seal clips/bolts
front air box door and hardware
vacuum actuator
actuator spring
bracket welded to hood for actuator
hose kit
6 hose kit clips
vacuum can with correct bracket
vacuum T in intake to feed can
air grabber switch, bezel, bracket, light
actuator solenoid relay ( not needed, as you can close door by flipping switch) (you will need bracket for the solenoid that mounts to switch if you use solenoid)
air grabber hood decal
air grabber decal for hood bubble door
4 bell nuts for rear of hood bubble
misc fasteners
air cleaner base-
Air cleaner lid, filter. filter decal. pie tin (71)
