Can someone explain to me what a windage tray does and how it's mounted in the oil pan?
Thanks.
Windage Tray
Windage tray keeps the oil off the spinning crank, reducing parasitic loss. It was standard on Hipo big blocks.
On big bocks, its sandwiched between the oil pan and block using an extra gasket.
On small blocks, it is mounted off the main bearing cap studs.
It was standard on all 340 engines471Magnum wrote:Windage tray keeps the oil off the spinning crank, reducing parasitic loss. It was standard on Hipo big blocks.
