Post by 71Beeper » Mon Nov 06, 2017 9:39 pm
So continuing on - I got a chance to finish welding up the edges of the trunk pan to the inner wheel housings.
With the car on it's side the tuff area's were easier to get to.
This is the passenger side.
And here's the drivers side.
If you look closely, you can see a partial part number.
Post by 71Beeper » Mon Nov 06, 2017 9:48 pm
And I also tackled that dreaded separated bottom lip on the drivers side. First I cut an access opening in the outer wheel housing to have a look on the other side.
Looks okay in there.
So, with the help of a few tools.....
I was able to close up the gap and put down some plug welds.
Post by 71Beeper » Mon Nov 06, 2017 9:55 pm
So, it went from this....
to this.....
I think it cleaned up this sill plate line pretty nicely (circled in red).
Midnight_Rider
My Cars: 71 Plymouth Road Runner
Post by Midnight_Rider » Tue Nov 07, 2017 12:32 pm
Good job! :beer:
My Cars: 71 roadrunner
Post by dangina » Tue Nov 14, 2017 9:32 am
looks good! also what photo hosting site are you using? I gotta change mine over from PB
Midnight_Rider
Post by Midnight_Rider » Tue Nov 14, 2017 4:37 pm
dangina wrote:looks good! also what photo hosting site are you using? I gotta change mine over from PB
Apologies, I know you weren't asking me, but it looks like they're just using the forum's 'upload attachment' feature?
But for other sites:
https://screenshot.net/sites-like-photobucket.html
My small local ISP actually allows me a small amount of FTP space that I upload pics to via Filezilla FTP client; may check with yours?. And I always process pics with photoshop's 'save for web' option before uploading, which drastically cuts down on the files size without noticably affecting the image quality. Hope that helps.
P.S. -- sorry OP, for the sidetrack/hijack
Last edited by Midnight_Rider on Wed Feb 28, 2018 9:32 pm, edited 1 time in total.
Post by 71Beeper » Tue Nov 14, 2017 10:39 pm
You are correct Midnight_rider, I use the forums upload attachment option.
But first I have to resize my photo's.
So after downloading my photo's from my phone to my PC I use the Windows Office picture manager program to resize the pics, so the will work with the forums upload attachment option.
Post by 71Beeper » Tue Nov 21, 2017 8:52 pm
So, moving on.......I started removing the old undercoating in the rear wheel well area.
And look what I find....... :shock:
More gold paint!
The more I scraped....
The more I found.
So I tried removing some off the rear frame section - More paint.
Now about that funny bracket that a previous owner welded on......I have no clue as to why it's there.
Originally I thought it might be there to hold the car down if it's on a car trailer, but then it looks to wimpy to do that. Anyway, I took off as much as I could on the inner wheel housing as I will be putting in new outer ones.
Post by 71Beeper » Sun Feb 18, 2018 8:42 pm
So now that I have this attaching picture thing worked out, back to this thread.
So in December, more scraping and undercoating removal. Here's the passenger side front corner.
Not very exciting pics here.
Just the clean-up of that area.
Here's the cleaned up torsion bar mount on the passenger side.
Post by rr6pak » Mon Feb 19, 2018 12:28 am
Since the car is on a rotisserie, wouldn't it be easier to blast it now instead of scrapping? What are you using and or doing to get it that clean?
Post by 71Beeper » Sun Feb 25, 2018 6:14 pm
rr6pak, I agree with you - it would be a great idea to sand blast it.
But you know the ol' saying "Champagne taste, beer budget" that's me.
My air compressor is in the garage that's attached to the house & it's about 100ft. from my garage that the Runner is in.
I don't have my big garage properly wired in right now. Believe it or not a heavy duty 100 ft extension cord is feeding my garage.
It works great, it feeds my lights and my mig welder with no issues.
I did purchase a small hand held blaster to get into the tight nooks and crannies that I can't reach by hand.
As soon as the weather warms, I'll try and run a 100 ft air line to the big garage and give it a try.
Here's my current arsenal of tools that I use to get it clean.
Feb 25 (5).jpg (129.28 KiB) Viewed 42523 times
Feb 25 (6).jpg (167.01 KiB) Viewed 42523 times
Feb 25 (7).jpg (161.95 KiB) Viewed 42523 times
Different size scrapers and a chisel (made by Sears go figure) as well as power tools. I use a fiber wheel mostly with the occasional use of a wire wheel.
Then I use the purple paint scraper wheel alot too.
I used the fiber wheel to clean the torsion bar mount and it came out that clean.
Post by 71Beeper » Sun Apr 08, 2018 5:08 pm
So after a brief hiatus, I'm back at it.
I mentioned in the past about this weird bracket that was on the frame rail.
Feb 25 (17).jpg (148.5 KiB) Viewed 42274 times
I decided to remove it. Now I know why it was there in the first place......to cover up 2 holes. :mad:
Feb 25 (2).jpg (123.15 KiB) Viewed 42274 times
So a while ago I bought a rear frame cap that Auto Rust technicians make. I bought it from a guy off of Moparts.
I was going to cap the whole frame section after I found the 2 holes - I even started to prep the cap for installation.
March 3 (4).jpg (229.78 KiB) Viewed 42274 times
But I decided against it. What I did was slice a piece off the cap to fit around the holes. Here's what it looks like already welded in place.
April 8 (13).jpg (109.03 KiB) Viewed 42274 times
After I finished that I started cleaning up the drivers area between the frame rail and inner wheel housing. Here's the progress.
April 8 (17).jpg (130.7 KiB) Viewed 42274 times
Post by 71Beeper » Sun Apr 08, 2018 5:12 pm
Some more progress pics.
April 8 (16).jpg (124.94 KiB) Viewed 42274 times
Here's a picture of the factory weld of the rear shock cross member to the frame - Now I know I'm not the worlds best welder but come on... :shock:
April 8 (15).jpg (144.27 KiB) Viewed 42274 times
After the area was cleaned up I shot a coat of primer on it.
April 8 (4).jpg (91.17 KiB) Viewed 42274 times
April 8 (6).jpg (100.62 KiB) Viewed 42274 times
April 8 (9).jpg (147.39 KiB) Viewed 42274 times
Post by rr6pak » Tue Apr 10, 2018 6:57 pm
Beeper, keep plugging away at it. Little progress is better than none. Hang in there.
Post by 71Beeper » Sat Apr 14, 2018 7:41 pm
Thanks rr6pak - I've been trying to get into the garage and work on her every weekend, but am currently helping my wife getting her parents condo ready to sell as they were recently moved into an extended care home. They are both 88 years young.
Once it's sold and the dust settles, I'll have a regular schedule back on my Runner. :beer:
