What Radiator setups are you guys using??
phatdak18
My Cars: 72 Plymouth Roadrunner
Post by phatdak18 » Sat Nov 05, 2016 4:36 am
I looking at buying an aluminum radiator. Right now im leaning towards a Be-Cool setup with dual electric fans, but there are SOO many choices available nowadays. I wanna hear what is working or not working for you guys. Most of what im seeing for our birds are 26" cores....is this pretty accurate or are you guys shoving bigger under your hoods? What about inlet/outlet positions? push or pull fans?
So, what do you got??
MOPAR OR NO CAR!!!
Re: What Radiator setups are you guys using??
Post by 71bird » Sat Nov 05, 2016 5:34 am
If you have the budget Glen Ray is the best and they look completely stock. Forget about the electric fans, and put the factory 7 blade with a fan clutch in. I have a 528 Hemi and never run over 180 degrees, and it looks factory.
steved
other stuff
Post by steved » Mon Nov 07, 2016 9:17 am
I've got an ECP. It does the job here on my 440 in Atlanta.
Post by road chicken » Thu Nov 17, 2016 5:41 pm
I'm running a 22" 4 core brass radiator with the 7 blade clutch fan and shroud. There is about 1.5" clearance with 195 T stat. it rarely moves off the 195 mark and thats usually in July Aug stuck in traffic. Even then no issues.
mclean03
My Cars: 74 Plymouth
Post by mclean03 » Thu Jan 26, 2017 2:09 am
Glen-Ray Radiator is the best yet pricey. Classic Industries has one that look close.
Philcollins
My Cars: 1972 Plymouth Satelitte Sebring
1971 Duster 340
Post by Philcollins » Sat Jan 28, 2017 9:50 pm
Running a 22" rad from a Dodge pick-up, stock fan clutch and shroud. 180 thermostat and don't run hot even in traffic. 360 with about 400 hp
Post by rr6pak » Sun Mar 05, 2017 7:35 pm
Glen-Ray. Yeah pricey but well worth it. Bob has the factory one running in a old car with a 572(?) hemi bored out.
Bruzilla
My Cars: 1974 Plymouth Roadrunner, 440/Auto, Black/Black
Post by Bruzilla » Thu Jul 13, 2017 10:05 am
I'm using a three-core Champion aluminum with a shroud and flex fan. Keeps my 440 at the right temp down here in Jacksonville, FL even when it's in the high-90s.
