Gas Tank
asuperdry
My Cars: 1972 RH23
Gas Tank
Post by asuperdry » Thu Feb 25, 2016 10:06 am
Correct me if Im wrong, but is this the correct gas tank for 71-72?
http://www.ebay.com/itm/Mopar-Fuel-Gas- ... K6&vxp=mtr
mrsnicks
My Cars: 1971 Plymouth Satellite Sebring Plus
Re: Gas Tank
Post by mrsnicks » Thu Feb 25, 2016 11:53 am
It's the exact same one I have in my 71 Charger.. same 4 side vents. CR10A
I'll crawl under my Satellite tonight when I get home.
Moparlar
And a roadrunner clone
Re: Gas Tank
Post by Moparlar » Thu Feb 25, 2016 4:23 pm
Its correct for a 71 and 72 up to I believe sometime in MArch when the vapor canister got moved to the front of the tank
1971 drag car
1972 440 6pack Roadrunner
Re: Gas Tank
Post by rr6pak » Thu Feb 25, 2016 6:18 pm
Correct and jsbrown AKA www.521restorations is a good vendor to deal with :)
72 cuda repli-mod
Re: Gas Tank
Post by 71_bronze_gtx » Sat Feb 27, 2016 9:00 am
Looks just like mine as best I can see with it in the car.
Raises a question for me:
How are the filler neck and pickup/sender assemblies attached? I can't see any evidence of screws on mine? Maybe it's in my service manual?
Re: Gas Tank
Post by rr6pak » Sat Feb 27, 2016 3:10 pm
71_bronze_gtx wrote:Looks just like mine as best I can see with it in the car.
The filler neck goes in a large "o-ring" type seal, sender is held in the side with a gasket and large lock ring that holds it in. All should come with a kit, I think. If you have the manual or parts catalog, it's in section 14, fuel. Both have pictures of what I'm talking about
72 cuda repli-mod
Re: Gas Tank
Post by 71_bronze_gtx » Thu Mar 03, 2016 5:07 pm
I have both 71 and 72 manuals, and neither one has a decent picture of the filler neck or the sender installations. However, a friend of mine showed me samples of both.
The piece they call a ground clip - this thing appears to make an electrical ground "jumper" around the short section of hose between the fuel line heading to the engine and the tube stub at the tank. I can't spot any ground clip on my tank, but the gauge works.
Re: Gas Tank
Post by sdweatherman » Fri Mar 04, 2016 3:08 am
You are correct - the jumper is for ground. Scott.
