Threaded vs Pressed Lower Ball Joint?
patrick
Post by patrick » Wed Jan 13, 2016 2:50 am
Guys and gals,
Why did my '73 Road Runner come with the threaded (read: more expensive to replace) lower ball joints such as the MOOG K719 versus the press-fit (MOOG K7069)?
What was the advantage, disadvantage, and why was it used on some Road Runners but not others?
Car is a factory 400/4-speed car.
100% Death Proof
Re: Threaded vs Pressed Lower Ball Joint?
Post by rr6pak » Wed Jan 13, 2016 7:57 am
I'm not 100% sure but I think it was a design change made by the engineers. Why and or is it beneficial, IDK.
steved
other stuff
Post by steved » Wed Jan 13, 2016 9:32 am
cost savings? if the pressed one came second in the production run, i'm betting they needed to save a little money somewhere. Threads cost money to make.
patrick
Post by patrick » Wed Jan 13, 2016 9:23 pm
Moog states if your car originally had threaded, you must replace with threaded, yet most front-end kits just give you the press-fit by default. Will they interchange?
100% Death Proof
Post by rr6pak » Thu Jan 14, 2016 12:57 am
patrick wrote:Moog states if your car originally had threaded, you must replace with threaded, yet most front-end kits just give you the press-fit by default. Will they interchange?
No. You have to know which kind, threaded or not, you have. That is unless you change the UCA
patrick
Post by patrick » Sun Jan 24, 2016 12:54 am
Seems weird to have two different types, especially since the control arm is different. Maybe it was a big block versus small block thing? Anyone here actually have the non-threaded type ball joints? I was talking about the lower ball joint, not the upper, by the way.
100% Death Proof
Post by sdweatherman » Mon Jan 25, 2016 2:33 am
My 1971 Sebring Plus had pressed lowers and threaded uppers. I think that is the norm for most of these cars. Scott.
