72 Road Runner
wejewill
My Cars: 1972 rm23 with GY8 color, D13 three on the floor, with a 440 4bbl, 323 gears, made in St. Louis plant LOVE IT!
72 Road Runner
Post by wejewill » Fri Mar 07, 2014 4:44 pm
Hello,
I was asked today about re-installing the gas tank on my 72 RR and if there is a pad, mat or rubber piece that goes between the gas tank and the underside of trunk floor? To keep the tank from creating a spark or something? I have not seen anything for the top of the tank, but I have seen rubber pads that is used between the strap and the tank.
Thanks,
Jeff
Re: 72 Road Runner
Post by 71bird » Fri Mar 07, 2014 6:08 pm
I think DMT has the most correct pad.
Re: 72 Road Runner
Post by sdweatherman » Fri Mar 07, 2014 7:00 pm
I sent Jim at DMT the measurements from my gas tank pad, but I have not checked to see if they have it available yet. Other vender pads are more of a foam consistency, whereas the real thing is more of a thick roofing felt type material. I expressed my concerns to Jim about the material, and he said that he had researched the material carefully. So his reproduction pads should be very nice. Here is a pic of my original gas tank pad. It measures 22-5/8" x 25-5/8". The material is approx. 3/16" thick.
wejewill
Re: 72 Road Runner
Post by wejewill » Sat Mar 08, 2014 9:24 am
Thanks I will look into it. I cannot believe that was not replaced if it worn out.
Uppy
My Cars: Present: 1971 Plymouth GTX
Past: 1970 Dodge Coronet 500
1973 Dodge Charger SE
Re: 72 Road Runner
Post by Uppy » Tue Mar 11, 2014 11:31 am
The pad was designed to keep the tank from making noise from the contact between it and the trunk pan. They tended to lose there waterproofing over the years and dry rot. They also ended up holding water, rotting both the trunk pan and the top of the fuel tank. The early aftermarket ones were made of rubber or foam rubber to prevent this. The factory was a waterproof impregnated paper product.
wejewill
Re: 72 Road Runner
Post by wejewill » Tue Mar 11, 2014 6:38 pm
Thanks, I just got more information about the original mat. DMT said the original pad was made out of asbestos material. I guess I do not want to go with that original pad. So I lose a few judging points that is better than my life :D
