1972 Code question
wejewill
My Cars: 1972 rm23 with GY8 color, D13 three on the floor, with a 440 4bbl, 323 gears, made in St. Louis plant LOVE IT!
1972 Code question
Post by wejewill » Wed May 29, 2013 5:26 pm
I have Five codes on my fender tag not sure of please help? My fender tag is below!
The first one is I believe to be either a Y23, or X23
The second one is G2X9,
The third is P2G it is located just before the sequence number
Fourth, the GY8 is in two places one is for the body color what is the other one for?
Fifth is the C21
My Fender Tag has this order:
R11 V8X 26 END
H51 L31 M21 M31 (Y23 or V23 or X23 again not sure what this number is) N41
GY8 I B41 B51 G11 G36
GY8 G2X9 TX9 C21 E38441
E68 D13 RM23 P2G 113866
Moparlar
And a roadrunner clone
Re: 1972 Code question
Post by Moparlar » Wed May 29, 2013 6:17 pm
wejewill wrote:I have Five codes on my fender tag not sure of please help? My fender tag is below!
The first one is I believe to be either a Y23, or X23 Not sure
The second one is G2X9, I believe Black Bench seat interior
The third is P2G it is located just before the sequence number P is 400 4bbl, 2 1972, G St Louis assembly
Fourth, the GY8 is in two places one is for the body color what is the other one for? Upper and Lower body color
Fifth is the C21 Build date 12/21
R11 V8X 26 END
1971 drag car
1972 440 6pack Roadrunner
Post by ILUV72RRs » Wed May 29, 2013 6:46 pm
Sounds like you have some rust or dirt on your fender tag. The so called X23 or V23 or Y23 in the position it's in should be N23 which is electornic ignition which was standard equipment on the 1972 Road Runners.
Post by ILUV72RRs » Wed May 29, 2013 6:48 pm
The G2X9 should be C2X9 for black deluxe bench interior. Sometimes it's easier to look at the back side of your fender tag to figure out what is stamped.
wejewill
Post by wejewill » Wed May 29, 2013 7:24 pm
To everyone,
You are the best thanks for all your help with the decoding. Again, Thanks so much. It is really hard to make the C2X9 out. It does make sense because I do have the deluxe black bench seat. Also, the C21 was confusing, I thought it was a date just not sure what?:D
gary
Post by gary » Sat Jun 01, 2013 2:09 am
Does anyone know a Good website for decoding a fender tag? I used one a few years ago that had you fill in the numbers and /or letters.I can't find that website now :beer:
Post by moparite » Sat Jun 01, 2013 12:09 pm
Gotgrey
My Cars: 1972 roadrunner
Post by Gotgrey » Tue Apr 22, 2014 5:47 pm
I realize this is an old thread but had some questions. The E38441 (order number) does starting with "E" mean it was built for Export? The other one was I thought I read to get A/C (H51) you had to up grade the transmission. No?
[URL=http://s817.photobucket.com/user/moparexpert1/media/IMG_0473_zps166765a4.jpg.html]Image
Post by Eric » Wed Apr 23, 2014 5:56 pm
Gotgrey wrote:I realize this is an old thread but had some questions. The E38441 (order number) does starting with "E" mean it was built for Export? The other one was I thought I read to get A/C (H51) you had to up grade the transmission. No?
Yes, if your VON starts with E it was a "build for export" car. What do you mean by upgrade the transmission? You could get A/C with manual or auto with most engines.
Gotgrey
Post by Gotgrey » Thu Apr 24, 2014 9:57 am
I read somewhere you had to upgrade the standard 3 speed manual transmission to a 4 speed or a Automatic when ordering A/C. I think I seen it on an option chart. Of course I could of swore I read you had to have a full vinyl top when you ordered a sunroof but i seen one with a canopy type so I'm probably mistaken.
Post by sdweatherman » Thu Apr 24, 2014 9:03 pm
Not up on the transmission requirements, but if you ordered A/C you got the 26" radiator instead of the standard 22". The sunroof option required a vinyl top - either full or canopy was acceptable. Scott.
Edit - Just looked this up on the Hamtramck website. You could not get A/C with either the Slant 6 or the 440-6 pack engines. Or you could not get A/C with an air grabber hood. An Automatic Transmission was required for A/C if you had the 318 or the 440 4bbl engines. Sheesh!
