MSD distributor
my74mopar
My Cars: !974 Plymouth Roadrunner with factory sunroof 360
MSD distributor
Post by my74mopar » Sun Feb 17, 2013 8:37 pm
I've got a 74 Roadrunner w/360, I'm replacing the factory distributor with MSD Standard Pro Billet Mechanical advance distributor, here's the problem, i cant get the distributor to drop in, the rotor does not match up with original mark. Any suggestions??
gcoupe72
Re: MSD distributor
Post by gcoupe72 » Tue Feb 19, 2013 12:13 am
Well, assuming they sent you the correct one, compare the length of the shaft to your stock one.
Compare the "screwdriver" end on the shaft to your stock one.
If these match, take the oil pump drive out of the block, and see if it'll drop in.
If it drops in, see if the end fits the slot on your o.p. drive.
I'm also assuming you're following the F.S.M. procedure for lining everything up?
Let us know the result.
Good luck!
