New Project
- My Cars: 1972 Satellite Sebring Plus
New Project
I bought a 1972 Satellite Sebring Plus that was in the process of being converted to a Road Runner Clone. Here are the tag numbers.
RP23 Plymouth Belvedere, Satellite Premium 2 Door Hardtop
M2r 400 190HP 1-2BBLS 8CYL 1972 Windsor, ONT, CAN
231303 Sequence Number
E63 383 cid 4 barrel V8 335hp
D34 Light Duty Automatic Transmission
TX9 Black Diamond Exterior Color
H6X9 Trim- High, Vinyl Bucket Seats, Black
Tx9 Black Diamond Int. Door Frames
128 Build Date: January 28
320488 Order Number
V4W ?
U USA specifications
26 26in Radiator
B51 Power Brakes
C12 ?
C16 Console w/Woodgrain Panel
C56 Bucket Seats
F11 46 Amp Alternator (std with AC)
G37 IS Dual Racing Mirrors
H51 Air Conditioning with Heater
J52 Inside Hood Release
L31 Hood/Fender Mounted Turn Signals
M21 Roof Drip Rail Moldings
M33 Body Side Moldings
R35 AM/FM Stereo Radio
END
Someone pulled the motor and stuck a 440 engine in this. Engine Numbers are F440 11 10. Since they did this I think I am going to keep going to convert it. They put a Road Runner hood with an Air Grabber System on it. So here is my question....This has a Tall Torker Eldebrock manifold with a carter afb 750 carb. The air grabber system cannot be installed because the manifold makes the air cleaner set to high. So what manifold and carb will work with this system?
320488 Order Number
V4W ?
26 26in Radiator
B51 Power Brakes
C12 ?
C56 Bucket Seats
END
Re: New Project
Here is a picture of how high it sits. Any help or advice on other stuff is greatly appreciated!! Here is a couple of pictures of the project.
Re: New Project
V4W is canopy vinyl top white
C12 is shoulder belts
Great car ... keep it a SSP!
Re: New Project
Thanks!
This is my first restore on a car. Always wanted a muscle car so I decided to give it a try. I am learning alot and have alot to learn! Oh and first on posting on forums. Had trouble with pictures. Still don't have that right yet.
I don't have the original hood just the Air Grabber hood and the whole system. So to keep it a SSP I would need to find a hood or are you saying keep the system and just don't change the emblems?
Re: New Project
Welcome to the Nest!
Great factory color combination, black with a white canopy vinyl top and grey along the bottom. I'd love to see it put back that way.
Re: New Project
Thanks for the welcome!
I was hoping someone had an idea of the best fit manifold for that hood. Since I pulled the motor an tranny to go through them to replace seals an gaskets. I will measure when I get them back in there to see if I can find one that fits.
I was thinking of going through the suspension also. Is there better suspension parts to use or just use the standard parts from a parts store?
- My Cars: 71 roadrunner
Re: New Project
a six pack manifold!!!
Re: New Project
rp is a Satellite Premium
m in vin number is a 400 2 bbl
there are no 71 -74 Belvedere cars 71 -74 they are Satellite line cars
Satellite IN 1972
RL Satellite
RH Satellite Sebring
RP Satellite Sebring Plus
rm road runner a roadrunner with a 440 4bbl or 440 6bbl is gtx road runner
Satellite IN 1971
RM ROAD RUNNER
RS gtx
there are no RL Satellite in 1971
in 65 -70
is Belvedere line cars
Satellite IN 1972
RL Satellite
Satellite IN 1971
RM ROAD RUNNER
RS gtx
in 65 -70
Re: New Project
Jagman wrote:Thanks!
Sounds like a very well optioned SSP. There are not many around in original guise and they look very good if done well and good color combo, so would returning to SSP also be an option? Here is a pic of mine. Satellite parts are easier (cheaper) to source as well.
Good luck.
Ian B.
Re: New Project
Sorry have been away doing the engine and tranny. I disassembled the engine all the way down to the block and it is at the machine shop now. I will hopefully get it back soon to start to put it back together with some added components for more horsepower. That's dipping into the paint fund so I am stuck at that stage.Sounds like a very well optioned SSP. There are not many around in original guise and they look very good if done well and good color combo, so would returning to SSP also be an option? Here is a pic of mine. Satellite parts are easier (cheaper) to source as well.
Yes, it's a possibility, I haven't ruled out anything yet. My dilemma is I wanted to paint it plum crazy purple with a black stripe down the side. With the black vinyl roof in great condition I thought that would look pretty awesome!
I saw the post of your restore and all the work you have done and it looks Great! Did you just replace the bushings on your suspension or everything?
Re: New Project
Hi Jagman,
How about incorporating your Plum Crazy plans in this SSP paint scheme? It would sure stand out.
http://www.oldcarbrochures.com/new/1203 ... 04-05.html
Cheers,
Ian B.
Cheers,
Ian B.
- My Cars: 71 Plymouth GTX (FC7 In-Violet)
Re: New Project
I think the oringinal colors are this car would be awesome, why change to In violet (plum crazy is a dodge color). Too many people go that way and I understand if there car didn't have cool colors like yours. Good luck
- My Cars: 1971 Plymouth Roadrunner 340 Auto EV2
Re: New Project
Cool project! You might consider selling the Air Grabber setup and going back to stock. Selling it would fund a lot of other parts you need. I'm sure you wouldn't have trouble finding a nice original Satellite hood either. Usually guys are trying to go the other way.
Good luck and keep us posted on progress!
- My Cars: 71 GTX
Re: New Project
Edelbrock Performer manifolds should fit under that Air Grabber.
