Anyone bought the Stinger 71/72 Air Grabber setup?
AZ-Nick
Post by AZ-Nick » Tue Dec 28, 2004 12:14 pm
Has anyone bought the Stinger 71/72 Air Grabber setup from them?
What did you think of there quality?
What are the remaining parts needed beside the stock flat hood to finish up a project like this?
air grabber
Post by 71440 gtx » Fri Dec 31, 2004 11:58 am
You need a complete air grabber switch, with hoses, vaccuum canister that goes on the pas. side inner fender, the hood activator and the bracket that holds it into place and the round plastic clips that hold the hoses in place. You will need to cut the hole in the firewall for the hoses to go through. Because I'm a Mopar nut and willing to lend a hand to fellow Mopar enthusiasts, I can provide a template from an original hood to make the proper cut outs if you so require.
Do you still think that you want an air grabber for your GTX? Give me a shout if you need anymore help.
Kevin
air grabber
Post by 71440 gtx » Fri Dec 31, 2004 11:59 am
Kevin :D
ccb_v2
Post by ccb_v2 » Fri Dec 31, 2004 2:47 pm
Can you use a Satellite hood as a base for an airgrabber setup, and just make the appropriate cuts in the hood?
Post by 71440 gtx » Fri Dec 31, 2004 9:50 pm
yes you do a 71 hood or a 72 :D
AZ-Nick
Re: air grabber
Post by AZ-Nick » Sat Jan 01, 2005 12:26 am
71440 gtx wrote:You need a complete air grabber switch, with hoses, vaccuum canister that goes on the pas. side inner fender, the hood activator and the bracket that holds it into place and the round plastic clips that hold the hoses in place. You will need to cut the hole in the firewall for the hoses to go through. Because I'm a Mopar nut and willing to lend a hand to fellow Mopar enthusiasts, I can provide a template from an original hood to make the proper cut outs if you so require.
Kevin
thanks for the imput.....
What do you do about the needed hood brace that is needed?
ccb_v2
Re: air grabber
Post by ccb_v2 » Sun Jan 29, 2006 4:28 pm
Kevin :D
This is something I am very interested in doing. What type of template do you have?
