dash lights pulse
71runnerm51
dash lights pulse
Post by 71runnerm51 » Fri Apr 02, 2010 9:29 pm
Out driving last night and I noticed the dash lights pulse, I checked the volt gauge seemed normal , It was intermitant ... of course they always get brighter the faster you go !!! loose wire? :help:
Re: dash lights pulse
Post by moparite » Sat Apr 03, 2010 12:55 pm
Check the rheostat. They get dirty and don't always work well.
JosephGiannini
Post by JosephGiannini » Wed May 05, 2010 11:36 am
check your load draw to the lights the fusable link and the switch itself sounds likea amperage problem that is causing the lights to dim. if everthing is fine calculate total electrical usage amd make sure you are running the correct alternator for your needs and regulator.
A Mopar god Is dead.
1972 roadrunner.
