Well, the owner before me boofed another 7 quart pan on a curb by accident, and unsuccessfully tried to repair it with JB Weld. No doubt that it sets low. So, in turn, I scraped it on a dip in the road and finished it off. I needed a replacement...
...Which ended up being the Milodon Street/Strip "Low-Profile" 7 quart pan, in black instead of gold. I believe the matching pickup is necessary if you want to use your additional capacity (Like landon said). Oil changes aren't too much more expensive, I do mine myself anyway. With this pan and the K&N HP-3001 oil filter, I use 8 quarts on the dot. I do have a windage tray that matches my crank, but I had that from my former setup. Windage trays are often used for high RPM's, it hugs the crank closely and scrapes off the excess oil, freeing up horses. Landon's right on the money about the baffle too. Good call!
I've been pretty happy with the setup and I believe I brushed it in the center of a driveway once. Other than that, it works well. For built engines, oiling capacity is much needed to feed the valvetrain up top. Honestly, regardless of setup, I don't think it'll hurt anything, just help.
The design of the pan is nifty with the lightly kicked out sump, it gives a little bit more clearance than your average high-quantity pan. Or at least my former one was just a square cube instead of a trapezoid shape and hung down an extra inch.
The Milodon could be easily bashed if not careful, then again if you don't live in rural nowhere like me, I wouldn't worry about it too much.
The only real con I have on this is ground clearance, I believe I have about 4"-5" of clearance from the bottom of the oil pan to the ground.
A nice pro of the factory style 6 quart Hemi pan is that it sits inside the K-Frame, which I would recommend for peace of mind. But don't let me discourage you!
I can post pictures of it if you wish...But other than that, if you have any more questions, let us know...Good luck!
