power steering pump??
fourforty6pac
Post by fourforty6pac » Wed Feb 21, 2007 5:44 pm
Sorry for the newbe question but my car came without the ps pump and I have no way of knowing what goes in there. What kind of ps pump goes in a 72 GTX? Is it a federal pump or a saginaw? The saginaw is the one that has the oval resivor. Thanks.
72Rdrnner
Re: power steering pump??
Post by 72Rdrnner » Thu Feb 22, 2007 1:04 am
fourforty6pac wrote:Sorry for the newbe question but my car came without the ps pump and I have no way of knowing what goes in there. What kind of ps pump goes in a 72 GTX? Is it a federal pump or a saginaw? The saginaw is the one that has the oval resivor. Thanks.
When you say "GTX" I assume you mean a 440 Roadrunner. As I understand the GTX was just a Roadrunner with a 440 (maybe 400) in 1972.
My parts manual says Power Steering Oil Pump w/key slotted pump shaft, except 318 part # 2891123
My power steering pump has the oval filler tube and the pulley is spoked and fastens with a nut and wodruff key on the shaft. It does not need a special puller to get it of, unlike those with a pressed on pulley.
You can get these at most good part stores, but then usually don't come with a pulley. I've found those at junk yards though. Just make sure you get one that fits the shaft on your pump.
As for the brakets...that's a whole different story. I don't know if a/c cars are different than non a/c cars as mine came with a/c.
Here's what the pump looks like.
