Last BIG works on my "PRO RUNNER"...
gary
Re: Last BIG works on my "PRO RUNNER"...
Post by gary » Fri Feb 15, 2013 12:36 am
WOW!!! Truely Awesome, Great work! :beer:
Post by road chicken » Fri Feb 15, 2013 7:54 pm
CtownRunner wrote:It feakin belongs as a feature in a magazine!
I'll second that!
Post by 71Beeper » Fri Feb 15, 2013 9:25 pm
Amazing amount of work done in so little time!!!! Congratulations! :beer:
gionni
Post by gionni » Sun Mar 03, 2013 4:20 pm
As I told you yet, I still had to install the EFI on the « Pro Runner »…
Now it’s done. After checking a lot of EFI-systems, I decided to buy the MSD Atomic EFI. If you looking for an EFI-system, I can really reccomend the Atomic. It’s a very easy and fast installation, no laptop is required, it’s possible to install it as a returnless-system, has cool features like timing-control or fan-control directly on the display of handheld-controller, and much more…
This is the Atomic EFI set…
First, I installed the O2-Sensor. So drilled a hole, welded in the thread port and mounted the sensor…
Next step was the fuel pump. The pump must be mounted as close as possible to the tank and below the lowest point of tank. So i builded a aluminium braket and installed the pump...
A big fuel filter must be installed between the pump and the throttle-body. I installed the filter in middle of car, next to the subframe connectors…
Between tank and pump a pre-filter must be also installed. Then I run the fuel hose along the car until the throttle-body…
Because I wanted to controlling the ignition timing through the EFI, i had to install a new MSD Pro Billet distributor with an adjustable rotor cap and a MSD 6A ignition box. To match the rest of engine bay, I painted the distributor-cap black and then I installed all parts…
Installed the temperature-sensor in the intake…
…and then the throttle-body! Fortunately the throttle-linkage and the keisler-sensor fits on the EFI linkage perfect, with no modifications!
Then I connected all electric-cables and installed the power module and the ignition box under the dash…
Connected the fuel hose…
…and connected the electrical cables on the fuel pump.
Next step was the handheld-display. I wanted to mount the display in my dash. But because the handheld is red like all MSD parts, i hat to painting it first black…
before…
and after….
I installed the display in the ashtray. For that, i had to modifying it, so i cutted a few parts out, welded a few parts in and cutted an opening for the display…
Then i painted all black and installed all in the car. Here how it looks…
Finally I reassembled the completely engine bay…
Here a little vid of the first start with the EFI. No throttle, no everything… I just turned the key and he started easily!
In the first 10 seconds he had to find his setup, but then the engine ran excellent…
http://www.youtube.com/watch?v=wYE3hUyff6I
The MSD Atomic EFI is a self-learning system. This means that the more you drive it, the further it sets itself and adapts to various conditions. These values are then stored and retrieved when needed, depending on the outside temperature, altitude or other conditions.
So now, I need just to drive it… ;-)
Post by CtownRunner » Sun Mar 03, 2013 4:42 pm
Can it get any Better!
asuperdry
My Cars: 1972 RH23
Post by asuperdry » Sun Mar 03, 2013 11:00 pm
:shock: OUTSTANDING! .....very cool 8)
Choucroute
My Cars: Plymouth Roadrunner clone 440 4 speed
Post by Choucroute » Thu Mar 14, 2013 8:20 am
What could I say after that ???? I'm wordless :shock:
I'M JALOUS !!!
SUPERMEGAGIGATERAENORMOUS WORK :beer:
Post by 71GTX » Sat Mar 16, 2013 4:24 am
sweet!
gionni
Post by gionni » Sun Mar 17, 2013 3:00 am
Thanx a lot... :beer:
steved
other stuff
Post by steved » Mon Apr 01, 2013 12:53 pm
Gionni, It's an inspiriation! GY9 has quickly become my favorite color. My GTX is this color, and might actaully...finally...get painted in the next couple weeks.
instead of doing my bumpers color matched, i think I'm going to have them painted bright silver...
I LOVE all the 3-d carbon wrap.
Just an incredible car.
RS23-71
Post by RS23-71 » Sat May 18, 2013 8:56 pm
Mind blowing beautiful........ 8)
Post by mopar71 » Mon May 20, 2013 10:55 am
That is one amazing car! :beer:
gionni
Post by gionni » Sat May 03, 2014 12:29 pm
Finally, i changed this winter the complete interior of „Pro Runner“. This is now the definitely setup for the interior. Here a few works and pics:
- Recaro-seats in front with custom-design in leather/alcantara (suede)
- Rear bench from a donor car (Alfa Romeo :D ) done with the same stich-design and leather/alcantara like front Recaros
- Rear floor modified for the new bench
- New dash-pad covered in leather with custom-stiches
- Console-center covered in Di-Noc 3D Carbon
- Steering-wheel rim covered in alcantara
Post by road chicken » Sat May 03, 2014 2:46 pm
Very nice work all around and one of the best I've seen done. A nod to you sir , for the craftsman you obviously are. :beer:
kenny
My Cars: RM23N1G107875
Post by kenny » Sat May 03, 2014 10:50 pm
that is fantastic looking, you have done a great job on everything
