- My Cars: 1971 Satellite
While the cowl area is exposed, I put some rust paint inside, to stop any more rust.
It looks like there will be two patches in this area - one partially over top the other as it looked from the factory. Here's a partial start on the first patch.
Along with a little welding.- rr6pak
- My Cars: 1971 Tor-Red RR
Few of many places that are common on these cars, Beeper. The rear 1/4 trunk extensions and wheel wells are other areas as well. I'm thankful that I had VERY little rust to deal with and my car was solid. Looking good and soon be ready for paint. Just don't get in hurry
I hear ya rr6pak - I do have new AMD trunk extensions along with outer wheel housings and full rear quarters for this car. When I had my 76 Road Runner, they too were notorious for rust in those area's as well.
All I did this weekend was close up the first patch from the previous weekend. Here's what it looks like from the inside the car.
Today I put on the second patch. I lined up the bottom edge with the existing bottom edge of the firewall that's on the other side of the inner fender. Unfortunately I could not put a bead on the patch like the rest of that panel has. Here's the patch before welding.
Now here it is welded in. And finally with a little clean-up.-
Now to finish up the rest of that area and put a coat of primer on it.
- My Cars: 1973 Roadrunner, 1974 Satellite
rr6pak wrote:Few of many places that are common on these cars, Beeper. The rear 1/4 trunk extensions and wheel wells are other areas as well. I'm thankful that I had VERY little rust to deal with and my car was solid. Looking good and soon be ready for paint. Just don't get in hurry
My Runner is a AZ car and the front of the quarters by the doors are rusted.
- rr6pak
Kind of odd if it spent all its life in Arizona, who knows.73'BIRD wrote:rr6pak wrote:Few of many places that are common on these cars, Beeper. The rear 1/4 trunk extensions and wheel wells are other areas as well. I'm thankful that I had VERY little rust to deal with and my car was solid. Looking good and soon be ready for paint. Just don't get in hurry
rr6pak wrote:Kind of odd if it spent all its life in Arizona, who knows.73'BIRD wrote:rr6pak wrote:Few of many places that are common on these cars, Beeper. The rear 1/4 trunk extensions and wheel wells are other areas as well. I'm thankful that I had VERY little rust to deal with and my car was solid. Looking good and soon be ready for paint. Just don't get in hurry
As far as I know it has
OK, so after a little hiatus, it is back to workin on the car.
I put some all metal down on the base of the windshield and sanded it down to finish. Here's the stuff I used. Next it was on to inside the cowl area. After scuffing the area down, I applied 2 coats of Rust Bullet. I did have to clean up the area on the drivers side where the reinforcement for the bracket that holds the steering column is located. You can't see the reinforcement as its higher in the picture.
I was able to get all the way in where the air inlets at either end of the cowl are located.
I applied the Rust bullet with a paint brush. The stuff is great as it flattens out on it's own.
- rr6pak
All Metal is good stuff. Keep up the good work
Thanks rr6pak, I'm trying to keep workin on it every weekend I get.
OK guys, back at it today. I'm sanding down the passenger side of the firewall. Since I have the passenger side inner fender out, I'll be prepping the area for the new inner fender to go on. So here's some pics of the sanding done.
Some sanding done down in the tranny tunnel area. . Also down on the frame rail area.-
Another frame area pic.
Boy I sure am glad there's good steel down in those areas. -
So, now I've finished up cleaning the frame rail area and shock tower.
So now it's time to add more Zero rust to the area. And while I'm at it, apply some to the frame too. Next to move on to the rad support on that side, then prep the new inner fender.
