Now available from RPM Restoration Parts, Inc. - Correct 1971-74 B-body window felts. Correct fitting and appearing kits.
1971-72 Dodge and Plymouth B-bodies
1973-74 Plymouth B-body with or without chrome bead on the outer felt. They used both, check your car to see which you have.
1973-74 Charger without rolldown quarter glass window. Same as above, they have either a chrome bead or black bead on the outer felt. Let us know which you have.
1973-74 Charger with roll down quarter glass. We need patterns. Please contact us if you have some we can use.
RPM Restorations Parts is now offering a Alternator and Starter restoration service.
We are working with a company called Dixie Restorations to provide show quality restored parts. Here are some of the details:
Quick Turnaround – usually less than two weeks excluding shipping.
We guarantee - all of our restoration work for a full year.
Alternators – complete disassembly and inspection followed by a thorough case cleaning. If case is damaged, you will be notified immediately. Diodes/rectifiers, stator and front housing bearing are replaced. Rotor is replaced or reconditioned to “like new†appearance and function. Small parts are replated or replaced as needed. Rear housing bearing is replated and reconditioned. Alternator pulley is carefully reconditioned or replaced. Restored unit is thoroughly bench tested to insure proper amperage output before being returned.
Starters - complete disassembly and inspection followed by a thorough case cleaning. If case is damaged, you will be notified immediately. Brush housing and bendix (five roller HD) are replaced. Stator windings and armature inspected, continuity tested, and replaced if necessary. Worn shaft bushings re-knurled or replaced if necessary. Stator winding housing carefully cleaned and repainted to factory specifications. Restored unit is thoroughly bench tested to insure proper operation being returned.
Your alternator and starter are tagged with the restoration assembly date, a digital picture of alternator amperage output and/or starter bendix engaged and packaged with warranty information.
Does it make sense to settle for a parts store rebuild when we can make your alternator and starter it’s own showpiece?
Contact us for more information at:
Phone: 770-975-9898
Website: www.rpmrestoparts.com
Email: mail@rpmrestoparts.com
						Correct fitting & appearing window felts for 71-4B's
