Hi all,
I finally got my car up on the lift the other day and had a good look around. I was going to try to figure out what gears were in it, so I jacked up the rear so the wheels could spin, and tried to count the turns. Problem was, it seemed like it slipped as I spun the driveshaft, so I couldn't do an accurate count. It wasn't total slippage, just enough to prevent me from counting. It's definitely posi though, both wheels spun the same way.
Is this normal?
8 3/4 question
- aerodynamic
- racedodge
- My Cars: 73 Plymouth Roadrunner, 400/727/3.23 originally
Re: 8 3/4 question
sounds like your unit may need rebuilt. the unit shouldnt slip under that minimal amount of stress. Turning in your car yes, turning the wheel by hand, no.aerodynamic wrote:Hi all,
Is this normal?
Does your rear end have an axle tag on the upper left hand side of the pumpkin?
KANSAS MOPAR CRUISE
71 Charger SE/Superbee clone (383/4spd), 73 Charger SE, 73 Roadrunner (440/727), 88 Dodge 1/2T, 06 Dodge Caravan SXT
TO LEARN ABOUT AUCTIONSNIPER!CLICK
- aerodynamic
Hmm
I'll have to check on that tag, I didn;t think to look there when I had it up. I'll probably rebuild it anyway, I don't know what it's been through with the previous owners.
Yeah, If its "slipping" that may indicate chewed up ring or pinion gear. Not good.
