				Some Fender code questions
				Posted: Fri Apr 15, 2016 12:13 am
				by 73'BIRD
				What is a deluxe steering wheel with roadrunner emblem (which emblem is proper for a 73)
When it says upper door frame white what does that mean?
Trim grade deluxe looks like?
Trim color black and white: what is black and what is white?
				Re: Some Fender code questions
				Posted: Wed Apr 20, 2016 12:52 am
				by sdweatherman
				Sometimes those decoders don't do a real good job of describing the codes/options. Throw us the specific codes and we will sort them out for you.
The upper door frame paint code I can help with. On most 71-74 Satellites/RRs, the door panel does not cover the inner door frame completely - you can see some body color paint when the door is closed along the bottom. So the factory painted the bottom edge of the door a similar or same color as the interior.
Trim grade deluxe & Black and white pertains to your seat/interior code possibly? Like P6XW?
Check out this website:
http://www.hamtramck-historical.com/index.shtml
And under the library tab:
http://www.hamtramck-historical.com/ima ... te0002.jpg
http://www.hamtramck-historical.com/ima ... te0003.jpg
Someone correct me if I am wrong - XW - Black and White interior - Carpet, Dash, and Steering column black, Seats and door panels white.
				Posted: Wed Apr 20, 2016 11:51 am
				by 73'BIRD
				Here is the fender tag done through the decoder
				Posted: Tue Apr 26, 2016 4:34 pm
				by sdweatherman
				Looks like that decoder works well for the 72-74 model year cars. Could you let us know where you found that online decoder? Thanks, Scott.
				Posted: Wed Apr 27, 2016 9:24 am
				by 73'BIRD
				sdweatherman wrote:Looks like that decoder works well for the 72-74 model year cars. Could you let us know where you found that online decoder? Thanks, Scott.
http://www.mymopar.com/index.php?pid=31
				Posted: Sun May 01, 2016 11:53 pm
				by sdweatherman
				Very good! I have not been back to this decoder page since this new version was uploaded. Looks like it is pretty easy to use.
				Posted: Mon May 02, 2016 10:28 am
				by moparite
				Get the little white books from Galen Govier,  Wealth of info! Well worth the price!!!
http://www.galengovier.com/whitebooks.htm
