Page 1 of 2
1974 Satellite fender tag
Posted: Sun Apr 03, 2016 9:38 pm
by 73'BIRD
tried to put this in the decoder and didn't work not sure I entered it correct. Could someone tell me about this car
Re: 1974 Satellite fender tag
Posted: Mon Apr 04, 2016 10:53 am
by moparite
Posted: Mon Apr 04, 2016 11:33 pm
by 73'BIRD
OK got it but one line confuses me:
KB5 - The provided code/year combo is currently undocumented
Posted: Tue Apr 05, 2016 6:27 am
by 71_bronze_gtx
B5 Blue - PPG Ditzler # 2627. Renamed Lucerne Blue Poly on the paint chart. I guess colors look better if you keep renaming them every couple of years.
Posted: Tue Apr 05, 2016 9:00 am
by 73'BIRD
71_bronze_gtx wrote:B5 Blue - PPG Ditzler # 2627. Renamed Lucerne Blue Poly on the paint chart. I guess colors look better if you keep renaming them every couple of years.
Ya that came up but the KB5 is repeated twice which results in that sentence I didnt understand
Posted: Tue Apr 05, 2016 11:44 am
by ILUV72RRs
The KB5 above the E24 is the car's body color. The other one above it is the top or roof color. If you have a vinyl top then this would be where that would be coded or if the car was available with a painted top, other than the body color, then the different paint code would appear in that spot. Hope this helps.
Posted: Tue Apr 05, 2016 3:11 pm
by moparite
Do you have the build sheet? If you look at it there are different lines witch have the same letter/# code on them as do the fender tag. It will give you a better way of understanding whats on the tag.
Posted: Tue Apr 05, 2016 3:32 pm
by Moparlar
Thats pretty much a Satellite With Manual Disc brakes, AM Radio, Manual Outside Mirror, Body side Moldings. 6 Cylinder, 3 Speed manual on the tree, Blue bench seat Blue paint
Posted: Wed Apr 06, 2016 8:51 am
by 73'BIRD
ILUV72RRs wrote:The KB5 above the E24 is the car's body color. The other one above it is the top or roof color. If you have a vinyl top then this would be where that would be coded or if the car was available with a painted top, other than the body color, then the different paint code would appear in that spot. Hope this helps.
Ya that makes sense so if it had another code it would have meant it was two tone or had a vinyl roof.
Posted: Wed Apr 06, 2016 8:53 am
by 73'BIRD
Moparlar wrote:Thats pretty much a Satellite With Manual Disc brakes, AM Radio, Manual Outside Mirror, Body side Moldings. 6 Cylinder, 3 Speed manual on the tree, Blue bench seat Blue paint
Thats not what it is now though. Its a 440/727 with bucket seats and no side mouldings
Posted: Thu Apr 07, 2016 8:10 pm
by sdweatherman
Most of the fender tag decoders on the web are for 1969-1971 cars. Most of the codes for 1972-1974 cars are the same, but several are different. I will check my book sometime tonight.
Posted: Fri Apr 08, 2016 12:28 am
by sdweatherman
E24 - 225 cu in Slant 6 - 1 bbl
D14 - 3 speed manual trans, column shift
KB5 - Body and Top color - Lucerne Blue Metallic
B2B6 - Vinyl bench seat - blue in color
000 - Full door panels - no trim paint required
508 - Scheduled production date - May 8th, 1974
949790 - Vehicle order number
U - Built for USA specifications
B43 - Front disc, rear drum brakes
G51 - Drivers side manual chrome mirror
R11 - AM radio (2 watt)
V5X - Black body side protective moulding
Y16 - Sales bank car
END - End of options codes
Posted: Fri Apr 08, 2016 1:22 pm
by moparite
by 73'BIRD on Wed Apr 06, 2016 9:01 pm
Im wondering what I should do to my 73 roadrunner. It came with a 440/727 from the factory but the engine and trans are gone.
What is the fifth digit on the vin plate on the dash? B, C, E, or T, U?
E24 is a 6 cylinder! That code was used in 72-74 Your vin code should be B C E depending on the configuration.
Posted: Mon Apr 11, 2016 4:10 pm
by steved
a blue on blue, disk brake, slant 6 car?
is it a 4 door?
Posted: Tue Apr 12, 2016 9:15 am
by 73'BIRD
steved wrote:a blue on blue, disk brake, slant 6 car?
is it a 4 door?
Nope
