`71 sunroof car fender tag
Just picked up a `71 road runner 340 sunroof car and trying to decode the fender tag. Is the sunroof code on there?
Re: `71 sunroof car fender tag
I read the code is not always on the tag?
71 st. louis cars no m51 but their should b a G99.... on the fender tag
So maybe it`s not a factory sunroof car, that sucks!
?11 26 END
EV2 U B11 M21 M41 N8?
EV2 M2X9 TX9 CO2 1868XX
E55 D21 RM23H1GXXXXXX
?11 26 END
That first line code is R11.
Two watt AM radio.
Dunno what the N8? one is though. Got pics??
Two watt AM radio.
The letter "N" is the engine accessories, If you have the build sheet you will see what options are in what letter section. It's possible it could have been installed on the dealer level. LETS SEE SOME PICS!!!!!
http://www.mymopar.com/6971opcodes.htm
It sucks but at this point I`m pretty sure it`s NOT a factory sunroof car but I did contact Jimmy and sent him the fender tag info so we`ll see what he says.
the hole is way to big . looks like somebody need a piece for another car
Does it have the vinyl top trim or at least the holes for it? Sunroof cars had vinyl tops.
Southwestern Sheet Metal
71-4 B-body
71-4 B-body
If it wasn`t for bad luck ...... confirmed NOT a sunroof car. No vinyl top, M51 code or G in VON. Will have to get more info from the guy I bought if from who is the friend of the owner and sorked the deal for me. He tolfd me, and I believe him, that the car had a sunroof and was cut out and is now in another road runner the guy owns. I now need to find out if It was actually a factory sunroof that was put in my car or it was just some aftermarket one. although to me it doesn`t really matter anymore. It`s still a cool car being a `71 340, 4 spd, EV2 but really not worth restoring.
What! A Hemi Orange 340 4-speed Runner black interior not worth restoring! That will be one sharp car when done, but it does look like a pretty tall project. You would have to do quite a bit of work yourself to not be upside-down when done. As you have found out - it is not a factory sunroof car. My bet is that it had an aftermarket sunroof in it. Since it is a RR and a 4-speed car, the N8 is probably N85 for a tach.
if it did have a factory sunroof in it removing dose not require cutting the roof the cassette for the sun roof
attaches inside with drain tube coming out in the rear wheel wells and down the windshield pillars....
hopefully you didn't get raked over the coals on price
