Heater / Vent Question for 1971
72 cuda repli-mod
Post by 71_bronze_gtx » Sun Nov 15, 2015 5:23 pm
For a car with no A/C and no Strato Ventil, it appears to me that the heater unit shares it's fresh air supply with the right side fresh air vent. Damper "closed" sends air into the heater. Damper open sends it into the cabin. Is this correct?
If the car has A/C does it come in the same way? Same way with Strato Vent?
72 cuda repli-mod
Re: Heater / Vent Question for 1971
Post by 71_bronze_gtx » Tue Nov 17, 2015 2:44 pm
Have to answer my own question. Thanks to my trusty borescope, I could see that there is no air passage in the center of the cowl down toward the trans hump to feed the heater box. So, yes, air enters via the right side vent tube.
I know everybody is very excited to learn this.
Post by 71bird » Tue Nov 17, 2015 7:26 pm
Sorry, but I couldn't ck my car cause it down right now.
moparmarks
Post by moparmarks » Sat Dec 05, 2015 10:35 pm
Yes you are correct. Should have a vent cable for the pass side as well as the drivers side.
Southwestern Sheet Metal
71-4 B-body
