Installation help with air grabber decal
Posted: Sat Oct 03, 2015 10:27 am
by 70 RR
I'm repainting my hood and the "R" in the word grabber is screwed up because it makes contact with the door pin and l guess it turns? Is there a cap or something missing that covers the pin? Please help, here is a picture showing my problem.
Re: Installation help with air grabber decal
Posted: Sat Oct 03, 2015 12:59 pm
by 72RoadRunnerGTX
Not missing anything, that’s how it was assembled. Decal installed after the pin. Pin floats, and was necessary to cut the decal around the pin head the remove. I changed the lever pin design on my current A/G, installed a nut insert on the outside, filled the pin hole outer surface, ran a screw and sleeve in from the inside.
Posted: Sat Oct 03, 2015 1:53 pm
by 70 RR
Thanks for the response, that's a great idea. I'm wondering if I put a small piece of electrical tape *just enough to cover the pin head) on the backside of the decal so it can't stick to the pin wouldn't do the trick? I'll figure it out, I'm just glad I'm not missing anything just another bad design.....
Posted: Sat Oct 03, 2015 3:16 pm
by 72RoadRunnerGTX
Have to consider a part of “good design” back then was to design them to be assembled as quickly as possible with no real concern about servicing or lasting more than a few years.
My old ’70 RR from back in the day:
Posted: Sat Oct 03, 2015 3:49 pm
by 70 RR
You've got that right. Those are both beautiful cars!
Posted: Sat Oct 03, 2015 7:09 pm
by dangina
72RoadRunnerGTX wrote:Not missing anything, that’s how it was assembled. Decal installed after the pin. Pin floats, and was necessary to cut the decal around the pin head the remove. I changed the lever pin design on my current A/G, installed a nut insert on the outside, filled the pin hole outer surface, ran a screw and sleeve in from the inside.
what a great idea! wish I have seen this a few months ago when I put my on
