AC blower motor wiring help. 72 Runner
sco440
- My Cars: 1972 Plymouth Road Runner
My question pertains to my AC blower wiring. According to my FSM p. 8-154 there is a green wire C5-14DGN attached to the air conditioning motor (assuming this is the blower motor). I have a green wire with a grey plastic boot plug plus a ground on the engine bay side of my blower. The FSM says this wire goes to the # 4 spot in the bulkhead. I am I reading it right? This powers the blower motor? When I hook it up like this I get nothing from my blower switch. What am I doing wrong?
- My Cars: 71 Satellite
Re: AC blower motor wiring help. 72 Runner
Assuming the 20 amp fuse is good and the blower motor ground is good, I'd check the following. Fuse output to the 5-terminal block on the control switch, the output from there to the blower switch connector, from there to the resistor block on the passenger side plenum, then from there to the to the bulkhead connector you described earlier and also out on the engine side of bulkhead (that connection is most likely to losen or corrode). You could work in reverse of its easier. Have you tested the motor with a jumper from a 12V source?
sco440
THX, it seems to be in the high med low blower motor switch. Got the blower to work by jiggling the switch but only on high level with ac lever on max. I have no med or low blower levels. Took the switch apart and cleaned terminals, no change. Do they go bad?
A faulty switch sounds reasonable. There are a couple of new ones on eBay now.
http://www.ebay.com/itm/1971-1972-Dodge ... 1305534069
