Ultimate Wiring Picture Guide 71 Plymouth / Dodge Bbody
- My Cars: 71 roadrunner
So since I'm running all brand new wiring, I bought a bunch of Harnesses from Year One(M&H), brewers performance and Mopar. I'm wasting a bunch of time trying to figure out what all these connectors are for and where they go. My goal for this guide is to provide a easy, picture diagram for those looking to hook up their car fast, and effectively with little to no time wasted. With each pick I'll provide the wire colors to the connector as the resolution may be off on some of your screens so you know exactly what your looking at. Keep in mind that these are aftermarket harnesses and may not coincide with the original colored wires, and that's where I need your help. I'm gonna keep this updated as best as possible,  What I need/want from the mopar community is to help me identify the connectors, and what they plug into. Just highlight the pic in the reply and type A) what its for, B) what it plugs into. Also, as I have found out already, do not throw away your old harnesses, some of the wires from your old harness may have to be reused with the new harness. If I had made a mistake, please let me know and I'll correct it asap.
Now let's begin:
													Now let's begin:
Re: Ultimate Wiring Picture Guide 71 Plymouth / Dodge Bbody
Main Dash Harness for 1971 Plymouth / Dodge Bbody With Rallye Dash (M&H Electric / YO):
(pic1)
(pic2)
(pic3)
1) 2 wires, both dark blue with yellow stripes
A) headlamp washer, whatever accessory on the car - rear deffog, powered trunk latch, A/C clutch source
B) This was used for more than one option, youget in fact those feeds full in 71, a bit less in 72. 73/74s got less accessories options and they got just one mold instead two on Harness. All extra stuff to be plugged on those molds USUALLY match the color of the molds on harness. You can see it on the A/C clutch feed of the pic 50, male is molded in yellow same as the harness mold... its a 20 amps fused source BTW
(pic4)
1) brown wire with white stripe
A) headlamp washer
B) The rubber grommet goes into the hole, through the fire wall, its the upper hole near the master cylinder (or booster)
(pic5)
1) dark blue wire with yellow stripe, black wire with red stripe
A) concealed headlamps
B) for dodge chargers not used on GTX/Roadrunner/Satellite
2) Other side of brown wire with white stripe
A) headlamp washer
B) engine side for headlamp washer
(pic6)
1) 2 solid orange wires, one red wire with white stripe, solid black wire
A) AM Radio
b) Radio Harness
(pic7)
1) solid tan wires to 3 port yellow female connector
A) accessory feed
B) ?
(pic8)
1) solid pink wire
A) stop lamp switch
B) switch on brake pedal
2) solid white wire
A) stop lamp switch
(pic9)
1) solid yellow wire, solid black wire, blue wire with white stripe, solid brown wire, solid red wire, solid orange wire, solid black wire, solid black wire
A) steering column
B) steering column harness
2) black wire white stripe, solid light green wire, solid tan wire, solid pink wire, solid red wire, solid dark green wire, solid brown wire, solid white wire
A) steering column
(pic10)
(pic10a)
1) solid pink wire, black wire with white stripe
A) hazard flasher
B) electronic flasher
(pic 11)
1) 2 solid black wires, 2 black wires with yellow stripe
A) headlamp-on warning buzzard
B) harness gets an extra pigtail to reach the buzzer mounted on dash frame between glovebox and ashtray. Buzzer gets a plug like the blinker flashers ones.
2) 2 yellow wires with black stripes
A) to ignition switch lamp time delay relay wiring
B) It is used for the little lite that shines from the steering column to the ignition key hole when the door is opened.
(pic12)
1) solid orange wire
A) cluster illumination lamp
B) back of rallye dash
2) solid tan wire
A) right turn signal indicator lamp
3) solid grey wire
A) oil gauge
4) solid dark blue wire
A) fuel gauge
(pic13)
2) solid violet wire
A) temperature gauge
3) black wire with white stripe
A) instrument cluster ground
B) voltage limiter have three prongs on back light face ( dunno if call it front or back LOL, because on standard cluster they are used backwards LOL )... two of them are actually an U shaped sheet. These two get the POSITIVE SOURCE from harness and the condenser noise suppressor which is attached with a phillips screw on back of cluster.. 3rd prong is the 5 volts output for gauges... it gets a small pigtail which sources all the gauges on the black wire.
The black wire with white stripe SHOULD be a wider terminal to be plugged onto the prong ( and bracket at the same time ) welded to voltage limiter "back case". This is made intentionally to NOT BE ABLE TO ATTACH by mistake the positive wire from harness on it ( would get a short as soon you put the key in RUN or ACC with this connected wrong ), since the prong on limiter case is also wider, matching the ground source plug
***UPDATE I had to rob the bigger black connector off of my old harness because M&H uses a smaller connector and it won't fit on the voltage limiter prong (easy to do, use a flat head precision screwdriver and go through the front of the connector - the opposite end the wire goes into - and slide the screwdriver between the plastic housing and the metal connector) pic13a shows the wire on the old connector and the new smaller one I pulled off the harness beside it***
(pic13a)
(pic14)
1) solid red wire
A) ammeter gauge
2) solid black wire
A) ammeter gauge
3) solid black wire
A) POSITIVE source for voltage limiter
B) plugs straight to voltage limiter double prong
4) solid orange wire
(pic15)
1) solid red wire, solid black wire
A) turn signal flasher
(pic16)
1) solid green wire
A) concealed headlamp relay
B) be sure to tape over the ring terminals or cut them out completely
2) 2 dark blue wires with white stripe
3) dark blue wire with yellow stripe, black wire with red stripe
(pic17)
1) solid red wire, solid pink wire
A) cigar lighter
B) cigar lighter back of ash tray
2) solid orange wire
A) ash tray receiver lamp
B) back of ash tray
(pic18)
1) 2 solid pink wires to 3 port red mold
A) battery feed
B) glove box lamp, map lamp harness
(pic19)
1) 2 solid yellow wires to 3 port black mold
A) Lamp ground
B) for map, courtesy lamp, open door indicator lamp, rear door light switch
(pic20)
1) yellow wire with black stripe, solid yellow wire
A) right front door automatic switch
B) passenger door switch
(pic21)
1) solid light green wire
A) left turn signal indicator lamp
3) solid orange wire
(pic22)
2) back wire with white stripe, dark blue wire with white stripe
A) brake system warning lamp
4) solid red wire
A) high beam indicator lamp
(pic23)
1) 2 solid yellow wires, 2 solid light green wires, one solid tan wire, one solid pink wire, one black wire with white stripe, one black wire with yellow stripe, one solid black wire
A) headlamp switch
B) headlamp switch back of rallye dash
(pic24)
1) is a 71 setup... the one piece plug to wiper switch began on 72, when wiper switches were smaller. Same wires though on diff prongs disposition
A) windshield wiper switch
B) wiper switch back of rallye dash
(pic25)
1) **the M&H harness just came with the black wire with white stripe, I had to add this to the red connector myself**one solid dark green wire, one solid light green wire, one solid brown wire, black wire with white stripe
A) heater blower switch
B) heater blower under dash passenger footwell, heater and A/C harnesses are separated from the underdash harness and instead are just linked ( according with your car equipment ) with the Underdash harness they are used to switch the input on the bulkhead for blower source green wire ( and blue wire clutch if AC ). If you had A/C must use the empty cavity on the A/C harness ( pic 49#2 ) to insert it there the black traced wire is left alone on the Underdash harness, just like I did with Heater harness.
(pic26)
(pic26a)
1) 2 solid orange wires, one solid black wire, one black wire with white stripe
A) light for Heater-A/C control face
B) plugs into a small pigtail harness for it using dual bulb on 71/72 correctly shown on 26 A (use from your existing harness)
(pic27)
1) solid orange wire to 3 port orange mold
A) accessory title lamp
B) lamp source for accessories switch under the dash... Air Ram, Rear Deffog, whatever switch down the dash driver side
A) ***from your old harness***
B) orange circuit is for cluster dimmed sources. Center console is the one I meant which dims out the same than cluster, and also radio faceplate ( hence the orange wire arriving to Radio )
(pic 28)
1) black wire with white stripe
A) parking brake lamp switch
B) to a switch on the emergency brake that triggers a light in the dash when the emergency brake is engaged or if the brake pressure fails. The switch is just a ground to activate the light.
2) 2 solid light green wires
A) time delay for headlights
B) delay relay gets an extra harness for that plug, separate option on B bodies, more common on C bodies
(pic 29)
1) one solid yellow wire, one yellow wire with black stripe, one solid black wire
A) left front door automatic switch
b) driver's side door
(pic 30)
1) solid black wire
A) harness ground
B) actually the underdash frame gets a J nut attached around the emergency brake area. Thats a ground source for the harness.
(pic 31)
1) solid dark blue wire, solid black wire, solid dark green wire, solid brown wire, 2 solid pink wires, white wire with black stripe
A) rear body harness to rear lights
B) yes some colors won't match... its on that way from factory. white with black trace becomes in violet for example... some other changes too.
2) solid pink wire, 2 solid yellow wires
A) to dome lamp
B) dome lamp harness , driver's side kickpanel
(pic32)
(pic32a)
1) violet wire with white stripe, solid light green wire, 2 solid red wires
A) foot dimmer switch
B) driver's side floor pan
													(pic1)
(pic2)
(pic3)
(pic4)
A) headlamp washer
(pic5)
A) headlamp washer
(pic6)
A) AM Radio
b) Radio Harness
(pic7)
A) accessory feed
B) ?
(pic8)
1) solid pink wire
A) stop lamp switch
2) solid white wire
A) stop lamp switch
(pic9)
A) steering column
A) steering column
(pic10)
(pic10a)
A) hazard flasher
(pic 11)
(pic12)
2) solid tan wire
3) solid grey wire
A) oil gauge
A) fuel gauge
(pic13)
(pic13a)
(pic14)
1) solid red wire
A) ammeter gauge
2) solid black wire
A) ammeter gauge
3) solid black wire
(pic15)
(pic16)
1) solid green wire
(pic17)
A) cigar lighter
B) back of ash tray
(pic18)
A) battery feed
(pic19)
A) Lamp ground
(pic20)
(pic21)
(pic22)
4) solid red wire
(pic23)
A) headlamp switch
(pic24)
(pic25)
(pic26)
(pic26a)
(pic27)
(pic 28)
(pic 29)
(pic 30)
1) solid black wire
A) harness ground
(pic 31)
A) to dome lamp
(pic32)
(pic32a)
Rear lamp harness (M&H Electric / YO):
(pic33)
(pic34)
1) solid dark blue wire, solid black wire, solid dark green wire, solid brown wire, solid grey wire, solid violet wire
A) rear lamp harness
B) to body wiring harness on main harness
(pic35)
1) solid violet wire, solid dark green wire, solid brown wire, solid black wires
A) rear taillights
B) rear taillight harness in trunk drivers side
2) solid black wire
A) taillight ground
B) ground to body
(pic35b)
1) solid grey wire, solid black wire
A) rear driver's side marker lamp
B) rear driver's side marker lamp housing
2) solid grey wire
A) rear driver's side marker lamp ground
B) ground to body
(pic35c)
A) sending unit
B) sending unit mounted in gas tank
(pic35d)
1) solid grey wire
A) trunk lamp (optional)
B) It plugs into the dark blue wire male end for the rear trunk light if you have the lighting package
													(pic33)
(pic34)
(pic35)
A) rear taillights
2) solid black wire
A) taillight ground
B) ground to body
(pic35b)
2) solid grey wire
B) ground to body
(pic35c)
A) sending unit
(pic35d)
1) solid grey wire
Clutch Safety Switch Wire (M&H Electric / YO):
(pic36)
(pic37)
1) solid dark green wire
A) clutch safety switch wire
B) to a single wire with a grommet through firewall when car is manual transmission
2) solid dark green wire
A) clutch safety wire
B) to starter relay "G" prong (when auto, this prong on relay gets the source from NSS tranny harness )
													(pic36)
(pic37)
Tach Harness (Charger Specialties / YO):
(pic38)
(pic39)
1) solid black wire
A) tachometer harness
B) negative post on ignition coil
2) solid black wire
B) to yellow accessory yellow mold
3) solid black wire
B) back of tachometer
4) solid black wire
													(pic38)
(pic39)
1) solid black wire
2) solid black wire
3) solid black wire
4) solid black wire
Electronic Ignition Conversion Harness (Mopar / YO):
(pic40)
(pic41)
1) green with red stripe
A) un-used in 4 pin ecu,
B) on 5 pin ecu, goes to "auxiliary" post ballast resistor
2) light blue with yellow stripe
A) ballast resistor "run" wire
B) "run side of ballast resistor
3) black with yellow stripe
A) ignition coil
b) to ignition coil negative
(pic42)
1) dark blue with white stripe, solid dark blue wire
A) distributor connector
B) on the distributor
(pic43)
1) blue with white stripe, solid blue wire, black with yellow stripe, green with red stripe, light blue with yellow stripe
A) control unit ecu harness
B) on the control unit on the firewall
													(pic40)
(pic41)
A) ignition coil
(pic42)
(pic43)
Windshield Wiper Harness (M&H Electric / YO):
***UPDATE had to switch the brown and red wire leads on the windshield wiper motor harness as they were backwards when plugged into the bulkhead***
(pic44)
(pic45)
(pic46)
(pic47)
1) solid red wire, solid brown wire, solid dark blue wire, solid dark green wire
A) wiper harness
B) windshield wiper motor
2) solid brown wire
A) ballast resistor
B) ballast resistor on wiper motor
3) solid brown wire
A) ballast resistor
4) solid dark blue wire, solid red wire, solid dark green wire, solid brown wire
A) wiper harness
B) main fuse block
(pic44)
(pic45)
(pic46)
(pic47)
A) wiper harness
2) solid brown wire
A) ballast resistor
3) solid brown wire
A) ballast resistor
A) wiper harness
B) main fuse block
AC / Heater Harness (M&H Electric / YO):
(pic48)
(pic49)
1) 2 solid tan wires, one solid light green wire, one solid dark green wire
A) blower switch
B) on back of rallye dash
2) light green wire with black stripe, solid brown wire, tan wire, one dark blue wire
A) AC and heater control switch
(pic50)
A) clutch feed
B) yellow mold accessory feed
(pic51)
A) clutch
B) just on 71 they used cavities left empty on neutral safety switch harness. 72/73 where shared between engine harness an NSS harness, using the green ( blower ) on NSS harness plug and Blue ( clucth ) on engine harness. 74s got a separate grommet for that on firewall due the lack of cavities left
2) 2 solid dark green wires
A) blower
B) same answer as 1B
(pic52)
1) solid tan wire
A) heater motor resistor
B) on the motor in the passenger footwell
2) solid light green wire, solid dark green wire, solid brown wire
													(pic48)
(pic49)
A) blower switch
(pic50)
A) clutch feed
(pic51)
A) clutch
A) blower
(pic52)
1) solid tan wire
Engine Harness For A 383-440 W/O Six Pack (M&H Electric / YO):
***UPDATE M&H for some reason moved the horn wiring from the lamp harness to the engine harness, and they moved the low brake switch wiring from the engine harness to the lamp harness. So if one wanted to run a mix of old harnesses and new, you would have to change these wires in the actual harness themselves to get it to work.***
(pic54)
(pic55)
1) solid grey wire, solid black wire, solid brown wire, grey wire with black stripe, dark green wire with red stripe, dark blue wire with white stripe, solid brown wire, solid violet wire
A) engine harness
B) plugs into main bulkhead
(pic56)
1) 2 solid brown wires
A) ignition ballast/resistor
B) above windshield wiper motor
(pic57)
1) dark blue wire with white stripe
(pic58)
1) solid grey wire
A) oil gauge wire
B) oil pressure switch on back of engine
(pic59)
1) solid dark green wire, dark blue with white stripe
A) alternator regulator
B) on the voltage regulator on firewall
(pic60)
A) carburetor solenoid, can be used if your running an electric choke
B) on carburetor
(pic61)
1) solid brown wire
A) ignition coil
B) positive post on the ignition coil
2) grey wire with black stripe
A) not used on GTX/Roadrunner/Satellite
B) Can be used for the TACHOMETER WIRE... negative lead of coil...the tach harness can use this cavity on back oh bulkhead ( number 20 ) instead use the grommet on harness to go through firewall
(pic62)
1) solid dark blue wire, dark blue wire with white stripe
A) from the ignition resistor/ballast
B) back of alternator
A) alternator field
(pic63)
1) solid black wire
A) Ammeter gauge wire
(pic64)
A) temperature gauge sending unit
B) temperature switch on engine
(pic65)
1) 2 dark green wires with red stripe
A) horn
B) for those equipped with dual horns
(pic66)
1) solid brown wire
A) windshield washer motor
B) windshield washer fluid bottle in the front passenger engine bay
2) dark green wire with red stripe
A) horn
B) horn front passenger engine bay
(pic54)
(pic55)
A) engine harness
(pic56)
(pic57)
(pic58)
1) solid grey wire
A) oil gauge wire
(pic59)
(pic60)
B) on carburetor
(pic61)
1) solid brown wire
A) ignition coil
(pic62)
A) alternator field
(pic63)
1) solid black wire
(pic64)
(pic65)
A) horn
(pic66)
1) solid brown wire
A) horn
Front Lamp Harness (M&H Electric / YO):
***Update M&H for some reason moved the horn wiring from the lamp harness to the engine harness, and they moved the low brake switch wiring from the engine harness to the lamp harness. So if one wanted to run a mix of old harnesses and new, you would have to change these wires in the actual harness themselves to get it to work.***
(pic67)
(pic68)
1) solid red wire, violet wire with white stripe, solid red wire, black wire with green stripe, solid black wire, black wire with brown stripe, black wire with yellow stripe, solid yellow wire
A) front lamp harness
B) bulkhead connector on firewall
(pic69)
1) solid black wire
A) low brake switch
B) located on your brake distribution block
2) solid red wire to solid blue wire
A) ammeter feed
B) to the "B" on the starter relay
(pic70)
A) starter relay
B) to the "I" on starter relay
(pic71)
A) harness ground
B) on radiator core support
(pic72)
1) 2 solid red wires, 2 solid black wires
A) left high beam lamp
B) inside lamp front grill, driver's side
(pic73)
1) 2 solid red wires, 2 violet wires with white stripe, 2 solid black wires
A) left low beam lamp
B) outside lamp front grill, driver's side
(pic 74)
1) solid black wire, black wire with yellow stripe
A) left marker lamp
B) inside driver's front fender
2) solid black wire, black wire with yellow stripe, black wire with green stripe
A) left parking light
B) front valance driver's side
(pic75)
A) right high beam lamp
B) inside lamp, front grill passenger side
(pic76)
1) solid black wire, solid red wire, violet wire with white stripe
A) right low beam lamp
B) outside lamp, front grill passenger side
(pic77)
1) solid black wire, black wire with yellow stripe,
A) right marker lamp
B) inside front passenger fender
2) solid black wire, black wire with yellow stripe, black wire with a brown stripe
A) right parking light
B) front valance passenger side
(pic67)
(pic68)
(pic69)
1) solid black wire
A) low brake switch
A) ammeter feed
(pic70)
A) starter relay
(pic71)
A) harness ground
(pic72)
(pic73)
(pic 74)
A) left marker lamp
(pic75)
(pic76)
(pic77)
Backup Light Harness (Brewers Performance):
(pic78)
1) solid black wires with black female 2 prong female plug end (3 prong for AutoTransmission)
A) for the backup lights
B) switch on drivers side of transmission
2) solid black wire, black wires with white stripe
3) black wire with white stripe with grey female connector
A) reverse light on dash
B) reverse light dash wire
													(pic78)
future posts
Not sure how M&H makes there harnesses and if there are slight differences for options/different years. Looks like most of it is labeled what it goes for. Start putting the harness in and a lot of questions will be answered as you will see where they go. You could see if they have a diagram with their color codes and compare them to the oem diagram. Worst case scenario get out the meter and check continuity from the fuse block/bulk head disconnect.
				TX9GTXN96
- My Cars: Present: '71 GTX 440+4bbl 4-spd 4.10 Dana GW3 GW3 J68 louver
On the top pictures of the dash harness, there are some extra wires and a firewall pass through grommet, that are not on my '71 GTX dash harness.  My guess is that they are for a '71 Charger, since the harness is made for both cars.  I'm going through the same thing with the YO/MH harness.
									My Mopars:
I have metered where the go (the unanswered ones) and they don't make any sense. for instance the 2 light green wires to a black female bullet connector goto to the bulkhead and to the foot dimmer switch. The only thing I can find in my manual (although its a 72) it just says "battery" not sure what plugs into it. Part of my problem is that I didn't pullout the old harness (its missing) so I don't know what goes where as I bought the project as a rolling shell and everything else is just thrown into boxes.moparite wrote:Not sure how M&H makes there harnesses and if there are slight differences for options/different years. Looks like most of it is labeled what it goes for. Start putting the harness in and a lot of questions will be answered as you will see where they go. You could see if they have a diagram with their color codes and compare them to the oem diagram. Worst case scenario get out the meter and check continuity from the fuse block/bulk head disconnect.
I have been trying to figure out what those ones are for, I was thinking of using the brown wire with the white stripe as my wire for my tach as the tach harness comes with a male/female bullet connector in the middle of it. the only difference is its a bigger grade of wireTX9GTXN96 wrote:On the top pictures of the dash harness, there are some extra wires and a firewall pass through grommet, that are not on my '71 GTX dash harness. My guess is that they are for a '71 Charger, since the harness is made for both cars. I'm going through the same thing with the YO/MH harness.
does anyone have a wiring diagram for the front headlight/horn/engine bay?
