hood insert hardware
- My Cars: '72 ROadrunner, 440, 4 speed, Dana rear
all matching - Location: Norfolk, UK
There are 4 flared 'hollow' spacers with thread and a small nut on the inside
Include a pic of the old broken bits.
Re: hood insert hardware
for some reason cannot upload the pic this morning, and it is small enough......
R/T Specialties, Bell nuts.
- rr6pak
- My Cars: 1971 Tor-Red RR
I'm looking at those as well. If I remember, you'll need four of them. What about the other fasteners and how many? I looked at R/T to try and find the others but didnt see them.72RoadRunnerGTX wrote:R/T Specialties, Bell nuts.
Looks like six of these 10-24 captured washer nuts as well. Looks like a pretty close reproduction.
Last edited by 72RoadRunnerGTX on Mon Oct 21, 2013 12:27 am, edited 1 time in total.
- rr6pak
Looks pretty goox to me. Thanks Doug!72RoadRunnerGTX wrote:Looks like six of these 10-24 captured washer nuts as well. Looks pretty like a pretty close reproduction.
Thanks Doug, that is the nut!!
I appreciate the help
Roel
Roel
- rr6pak
Just ordered the bell nuts and the others. Tom also has the screws for the rear tail lights. Just FYI
- rr6pak
Recieved the bell nuts and the other nuts for the call outs from R/T yesturday. Also ordered the correct screws for the tail light lenses from them as well. WOW.
- My Cars: 1971 Plymouth Roadrunner
RR6PAK, did your taillight screws fit your lenses good and snug? I ordered mine from R/T specialties as well and mine were too long. I also ordered all new bell nuts for my hood inserts and they were too thick to start on my original studs.
- rr6pak
I didn't know there was an issue with the bell nuts or the tail light screws. It will be a while till I know the fit of them since the car is all stripped and at the body shop. I can take one of the new bell nuts and compare with to one of the old ones. Sorry, that's the best I know right now. Hope there isn't an issue because this will be another issue of parts not fitting rightKentuckyBlueBird wrote:RR6PAK, did your taillight screws fit your lenses good and snug? I ordered mine from R/T specialties as well and mine were too long. I also ordered all new bell nuts for my hood inserts and they were too thick to start on my original studs.
Sad thing is I talked Tom into making the tail light screws and even gave him an original. How the repops came out too long I have no idea. At least the thread pitch is correct. You can cut them off, tap them, and they're fine.KentuckyBlueBird wrote:RR6PAK, did your taillight screws fit your lenses good and snug? I ordered mine from R/T specialties as well and mine were too long. I also ordered all new bell nuts for my hood inserts and they were too thick to start on my original studs.
- rr6pak
If that's the case Eric, I'll have to do that.Eric wrote:Sad thing is I talked Tom into making the tail light screws and even gave him an original. How the repops came out too long I have no idea. At least the thread pitch is correct. You can cut them off, tap them, and they're fine.KentuckyBlueBird wrote:RR6PAK, did your taillight screws fit your lenses good and snug? I ordered mine from R/T specialties as well and mine were too long. I also ordered all new bell nuts for my hood inserts and they were too thick to start on my original studs.
FYI, the originals looked like this. (on the left)72RoadRunnerGTX wrote:R/T Specialties, Bell nuts.
[/URL]
On the right is what I machined out of aluminum. The original ones would rust as they trapped any water that came down through the holes. The ones I made let the water run throught.
