Hood adjustment
Posted: Mon Sep 16, 2013 12:44 pm
I installed a different hood on my 72 Sat today so I could check all the panels and make sure everything fits right before I strip it back down and paint the car. The old hood was warped and unusable and the old hinges were worn out. I used some good working hinges from my 72 parts car and a good straight hood from a RR.
Everything operates properly now and lines up good with the exception of the side to side gap between the fenders. The left side (from standing in front of the car) has about a 1/16" gap and the right side has a 3/8" gap. I tried tweaking it and that does get the hood over pretty close to even on each side but as soon as you open and shut the hood again, it goes back to a 1/16" Left and a 3/8" Right gap.
Is there something I am missing here? I considered putting a washer on the 3 bolts, in between the inner fender well and the hinge on that left side to try and get the hinge to move over a bit but I figured I would ask you guys before I go through the trouble as it might not work anyway.
Any help or advise is appreciated. Thank You
