Axle seals
Posted: Sun Apr 28, 2013 3:22 pm
by Smellslike1974
Apparently one of my outer axle seals are bad. Axles/rears are new to me.I have searched around but I am not exactly sure what I need for my 8 1/4 rear. Can someone help me out with this.
Re: Axle seals
Posted: Mon Apr 29, 2013 9:44 am
by sdweatherman
If I have time this afternoon, I can get some pics posted for you. 8 1/4" rearends are pretty straight forward. If all you have to do is replace the seal, its a pretty simple job.
Re: Axle seals
Posted: Mon Apr 29, 2013 1:15 pm
by Smellslike1974
That would be great!
Re: Axle seals
Posted: Mon Apr 29, 2013 6:36 pm
by sdweatherman
Like I said in the previous post, 8 1/4" axles are pretty straight forward. The only bummer is that you have to remove the rear cover and drain the gear oil. Throw some jack stands under the axle and pull the tire or tires off if you are doing both sides. I think I remember you said you had a sure grip, so your diffy will look a little different than what I have pictured. You don't have to remove the differential carrier! I just had an extra one laying around for easy picture taking.
First thing to do is to find the small bolt in the carrier that holds the large center pin in place. This pic shows the hole that the small bolt came out of.
This pic shows the large center pin that has to be tapped out to get access to the C-clip that holds the axle shaft in place.
Slide the large pin out of the way and push the axle shaft towards the center of the car. This will allow you to slide the C-clip off the inner end of the axle shaft.
Once the C-clip is off, the axle shaft will slide right out of the axle housing.
Once the axle shaft is out, the seal is right at the end of the axle housing. Just pry out the old seal and gently tap in the new seal. While you are in there, make sure you inspect your bearings and axle shaft surfaces for unusual wear. This pic shows what the outer bearing and the outer seal look like.
And to quote Chilton - "Assembly is the reverse of disassembly"
Re: Axle seals
Posted: Mon Apr 29, 2013 7:18 pm
by Smellslike1974
Thank you so much!Ill have to print this out for when i do everything.While i have everything apart ill check the bearings. I thought i had a sure grip but its just a limited slip.
Searches bring up alot of things and im not sure what type i need. Are these the seals I need?
http://www.summitracing.com/parts/rat-6124/overview/
I figured anyway I would jack the back up,take it all apart and see what I need before ordering. Instead of making separate orders if I need anything else.
Thanks again!
Re: Axle seals
Posted: Mon Apr 29, 2013 7:48 pm
by sdweatherman
Yep, Axle seals for Chrysler 8.25. The picture is not exact, but it says that it is just a "representative" picture of the part. If you live in or are close to a decent sized town, there should be a shop that specializes in bearings. They would most likely have your seals also. You could check on bearing availability also. Good luck with your project! Scott.
Re: Axle seals
Posted: Tue Apr 30, 2013 1:33 am
by gary
A word of advice.Try to find Bearings & seals made in USA.If you get China,Taiwan or Korean parts they won't last.Timken may still have American bearings. Just sayin'
Re: Axle seals
Posted: Tue Apr 30, 2013 9:42 pm
by Smellslike1974
It's tips like that is why I love this forum. Thanks Gary!
Re: Axle seals
Posted: Wed May 01, 2013 8:29 am
by 71bird
The only way to get U.S. made Timken bearings is take the part number off of the bearing to a industrial supply house. The Timken bearings sold at NAPA and ect. are imported.
Re: Axle seals
Posted: Wed May 01, 2013 12:26 pm
by gcoupe72
[quote="sdwea\
Like Scott said, don't ignore wear on the axle shaft where the bearing or seal "rides" or you will be doing this job again!
Re: Axle seals
Posted: Fri May 03, 2013 11:10 pm
by Smellslike1974
71bird wrote:The only way to get U.S. made Timken bearings is take the part number off of the bearing to a industrial supply house. The Timken bearings sold at NAPA and ect. are imported.
Summit Racing too I suppose?
Re: Axle seals
Posted: Fri May 03, 2013 11:36 pm
by 71bird
I don't know about summit, I would say they are imports. Now if you go to a industrial supply they can't go by Chrysler part numbers, they need the number off the bearing and the race.Thats what I did on some of mine.
