original paint color for 383 engine?
RICK71ROADRUNNERFJ6
My Cars: 1971 sassy grass green roadrunner---with full vinyle black top
1971 hugger orange chevelle
Post by RICK71ROADRUNNERFJ6 » Sun Nov 04, 2012 2:05 am
i recently bought a 71 rr-- it is suppose to be the original drive train in it!!! I noticed the engine itself was painted blue????? thought it was suppose to be orange---? were 383's painted blue and 440's painted orange?? anyone know these little bit of info?? or have an original 71 383 engine bay to show me!!! also can i get teh beep beep horn online----missing that also!!!
mopar boy
My Cars: 1971 Plymouth Satellite Sebring Plus 318
1970 Plymouth Road runner
2009 Dodge Challener R/T
Re: original paint color for 383 engine?
Post by mopar boy » Sun Nov 04, 2012 3:53 am
71 383 should be orange. Check if someone dropped in a 400 (painted blue from factory).
mopar boy
Post by mopar boy » Sun Nov 04, 2012 3:54 am
check ebay for your beep beep horn..or repro vendors.
RICK71ROADRUNNERFJ6
Post by RICK71ROADRUNNERFJ6 » Sun Nov 04, 2012 4:03 am
thanks i will check on that----i hope they just painted it blue====!!
Post by 71bird » Sun Nov 04, 2012 9:59 am
Ck everything out. The original owner of my RR blew the engine up,and the dealer put a 400 in under warranty,they had stopped production of the 383.Look on the right side of the block right above the oil pan to ck the vin.The last numbers should be the same as the car.If its blank it could be a warranty eng.And the other person could be correct also,just a 400 from the junk yard.
Post by 471Magnum » Sun Nov 04, 2012 10:53 am
Is it an A/C car? Is it blue or turquois? Check the vin stamp and casting numbers.
Several potential explanations, but best not to speculate without the above info.
RICK71ROADRUNNERFJ6
Post by RICK71ROADRUNNERFJ6 » Sun Nov 04, 2012 7:42 pm
it is not an original A/C car and the paint is more turqoise--not regular blue---does that make a difference?
Post by 471Magnum » Sun Nov 04, 2012 10:33 pm
If it's really turquoise, it's a 383 from an earlier model year. Turquoise was phased out during the 1970 model year.
383 4BBL A/C cars tended to get turquoise or blue engines, although there have been exceptions noted.
Note that turquoise tends to fade to a light blue and often gets mistaken of the later corporate engine blue, especially when you find it under a later of orange. :roll:
That said a 71 383 HP should be orange. You need to check your numbers.
RICK71ROADRUNNERFJ6
Post by RICK71ROADRUNNERFJ6 » Mon Nov 05, 2012 12:38 am
the RR was made on sept. 16 1970 --maybe it was painted that color--i will check on that this week! i hope maybe they painted over the orange----i am getting it delivered this week from the guy i bought it from!---OK if i open the hood and look at the engine----what side do i look under to see the matching numbers--view point straight at the shroud fan looking in!!
Uppy
My Cars: Present: 1971 Plymouth GTX
Past: 1970 Dodge Coronet 500
1973 Dodge Charger SE
Post by Uppy » Mon Nov 05, 2012 7:44 am
Vin number will be on passenger side located along the bottom edge of the engine block where it meets the oil pan. There should be an area that is machined flat (a long rectangle) and has your vin number in it. Also, 383 2 bbl cars where painted turquois. I know RR's were not 2 bbl cars, but SSP's were. Transmission has same thing, passenger side but usually exhaust is in the way to get a clear look at numbers. I hope this helps. Someone probably just liked the blue, or ????
Post by Eric » Mon Nov 05, 2012 6:12 pm
Do you know the VIN number of the car? To be an original road runner it needs to start with RM23.
RICK71ROADRUNNERFJ6
Post by RICK71ROADRUNNERFJ6 » Mon Nov 05, 2012 9:36 pm
yes the vin number of the car is RM23N1R117246-----the code tag on the drivers side in the engine bay is-- R26 V21 END F91 G36 J52 M21 N41 N42 V1X U 22 B51 C21 C55 FJ6 M6x9 TX9 916 016716 E65 D32 RM23
N1R 117246
Post by Eric » Tue Nov 06, 2012 6:22 pm
Good....I've seen Satellites advertised for sale as road runners....someone not knowing the proper VIN could buy a clone and not know it.....
Cool options. The F91 is probably F81. No matter what the decoders say, on a 71 runner this does not indicate a remote trunk lid release. It's an unknown code that shows up on some Winsor built cars.
Does your car have wheel opening moldings and rear bumper/valance blackout stripes?
RICK71ROADRUNNERFJ6
Post by RICK71ROADRUNNERFJ6 » Tue Nov 06, 2012 10:51 pm
i looked on the back bumper --did not see the black stripe on it --but bumper was looking kinda rough---they could have fallin off in time---looks like the original bumper---rusted--the car has been sitting since 1986---motor turns---but i will go thru it anyways---ALSO the front bumper and grill and other parts are in the trunk---i will look for open wheel moldings!!! missing the little roadrunner head that was on the front of the grill---noticed that !! ggrrr!
gcoupe72
Post by gcoupe72 » Fri Nov 16, 2012 3:09 pm
RICK71ROADRUNNERFJ6 wrote:i recently bought a 71 rr-- it is suppose to be the original drive train in it!!! I noticed the engine itself was painted blue????? thought it was suppose to be orange---? were 383's painted blue and 440's painted orange?? anyone know these little bit of info?? or have an original 71 383 engine bay to show me!!! also can i get teh beep beep horn online----missing that also!!!
Late production 340s have been documented to be blue, in B and E bodies in '71 model year.
Does anyone in the nest have an original engined '71 with a blue B or RB engine?
