body work
Posted: Sun May 13, 2012 2:23 pm
by redline337
Re: body work
Posted: Sun May 13, 2012 2:40 pm
by GTXS
If you cant' get behind it to pound it out out, you will have to pull it out. You could go old school on it and drill along the crease and use a slide hammer to pull it out. Or you could weld on some studs and pull it out. Maybe you could rent that. If you dont have the tools take it to a body guy and pay them to pull it out. Then finish it your self. It is not bad enough to replace. That would creat way too much work.
Re: body work
Posted: Sun May 13, 2012 6:11 pm
by rr6pak
GTXS wrote:If you cant' get behind it to pound it out out, you will have to pull it out. You could go old school on it and drill along the crease and use a slide hammer to pull it out. Or you could weld on some studs and pull it out. Maybe you could rent that. If you dont have the tools take it to a body guy and pay them to pull it out. Then finish it your self. It is not bad enough to replace. That would creat way too much work.
I agree with GTXS. My car had the exact same thing where someone had rubbed up against a pole at one time. It took my body guy to weld in 5-7 little studs and pull it out. He did have to use a VERY little filler to make the contour of the fender but it looks great. As said, welding in a whole new pice would be more pain and hassle than its worth. If you dont know a body guy, ask a friend that knows. Eastood has a stud gun cheap but a body guy should have one too. I'm no body guy but I would think you should get that fixed at a max of $300 maybe(?) Good luck and post what happends
Re: body work
Posted: Sun May 13, 2012 8:00 pm
by GTXS
When pulled out the metal will want to go back to it's original shape. It has a memory probably better then mine.
Re: body work
Posted: Sun May 13, 2012 9:46 pm
by rr6pak
GTXS wrote:When pulled out the metal will want to go back to it's original shape. It has a memory probably better then mine.
Re: body work
Posted: Sun May 13, 2012 11:48 pm
by redline337
Thanks for the info! I do know a body guy that is part of our local mopar group. I'll have him take a look.
Re: body work
Posted: Mon May 14, 2012 12:15 am
by rr6pak
Reline337 that looks like a fairly simple repair/fix. If the guy you know knows body work, he should hve no problem fixing it for ya.
