Which Pistol Grip Shifter ?
Posted: Sat Dec 17, 2011 12:24 pm
by ralley72
Which pistol grip shifter is correct for my 1973 Road Runner, P code 400, bucket seats without console or buddy seat? The handle that came with my car is taller than the short one that came in my 73 Rallye Charger without console or buddyseat. I have seen a couple 73 4 speed cars with the same handle as mine, but I keep being told its the wrong one.
Re: Which Pistol Grip Shifter ?
Posted: Sat Dec 17, 2011 1:35 pm
by 471Magnum
Where is your shifter hole located? The longer handle is for use with buddy and bench seat cars where the shifter comes through the floor in the forward position, in front of the seats.
Shorter one is common with E-bodies and the shifter hole is between the seats.
Posted: Sat Dec 17, 2011 3:57 pm
by 72RoadRunnerGTX
ralley72 wrote:Which pistol grip shifter is correct for my 1973 Road Runner, P code 400, bucket seats without console or buddy seat?
As mentioned and to elaborate just a bit; from your description, the short shifter handle should be correct for your car. The floor hump currently in the car will determine which handle fits correctly, yours should have the shifter mechanism mounted on the aft transmission mounting point, aft of the trans cross-member. Again, same components/configuration used on manual E-bodies. Bench seat and buckets with a buddy seat used a floor hump accommodating the use of the forward transmission shifter mounting point, forward of the cross-member and the longer shift handle.
Posted: Sun Dec 18, 2011 10:35 am
by farmboy70
The longer handle I believe would also have the bracket that lifts the shifter mech higher also. Correct??
Posted: Sun Dec 18, 2011 10:57 am
by 471Magnum
The bucket/console manual shift mounts to the tail housing of the transmission.
The bench shifter mounts to the main housing.
Both use an adapter plate IIRC.
Posted: Sun Dec 18, 2011 1:47 pm
by 72RoadRunnerGTX
Technically both shifter locations are cast into the tail shaft housing of later 833s. Both require an adapter plate but the adapters are not the same for the two configurations.
Forward
Aft
