Page 1 of 2
big block valve cover question
Posted: Fri Mar 04, 2011 5:55 pm
by tor-red
I have a couple of sets of 74 big block valve covers. what are the differences between 72 and 74 valve covers. I will be putting a 72 400 in my 72 SSP and would like to have it looking correct. I know there are some extra brackets on the later covers. Would I be able to just remove the unneeded brackets and clean them up or are there other things that are different besides the extra brackets? Any pictures would be appreciated. Thanks!
Re: big block valve cover question
Posted: Fri Mar 04, 2011 9:42 pm
by 72RoadRunnerGTX
72' Big blocks in these cars used covers configured as shown. No brackets on the driver's side at all, I removed some plug wire brackets from the cover pictured as it was from another application. Carefully grind down the small welds and fill any low spots. The passenger side cover has three wire loom wraps and two plug wire brackets for the #8 wire.
BTW, the missing/damaged rubberized coating on the brackets are easily replicated with a product called Plasti Dip, found at your local hardware store.
Posted: Fri Mar 04, 2011 10:23 pm
by tor-red
Thanks for the pictures and info. Now I have something to do tomorrow morning. Thanks Again!
Posted: Sat Mar 05, 2011 10:10 am
by Moparlar
The 72's I have had also had a tab on the passenger side cover where a holder clipped on to support the emission hoses going to the carb from the vapor canister.
Larry
Posted: Sat Mar 05, 2011 12:22 pm
by 72RoadRunnerGTX
Love to see a picture of it Larry, none of my original 72' BB covers have that. Don't recall every seeing anything for the vapor lines on anything else. Is that your v-code car?
Doug
Posted: Sat Mar 05, 2011 12:29 pm
by Moparlar
It was on my 72 440 4 bbl car built in Sep 71 and also on My blue sky 400 auto car built i believe in apr or may of 72. I will look at work I am pretty sure I have another bracket and valve cover with the clip on it. If you have a copy of MCG April 1994 my car was on the cover there might be a picture in that article. All my mags are stored away right now
Larry
Posted: Sat Mar 05, 2011 2:05 pm
by 72RoadRunnerGTX
I will have a copy of it in a few days! That's your car on the cover?
How original was the car in 94'?
Posted: Sat Mar 05, 2011 3:05 pm
by Moparlar
It was my car i let the wife have it in the divorce. It was restored by me if you look in a parts book you can find a part number for the support bracket.
Larry
Posted: Sat Mar 05, 2011 6:16 pm
by 72RoadRunnerGTX
So it would appear that this bracket(support) was not welded to the valve cover. I was thinking more in terms of a different cover part numbers for different welded bracket configurations used in 72'. Never found a picture of it in the parts book but clearly this description fits, very curious as to what it looks like.
Posted: Sat Mar 05, 2011 6:49 pm
by Moparlar
That is the support and there is a clip welded to the valve cover it clips on to
Larry
Posted: Mon Mar 07, 2011 10:37 am
by Moparlar
Here are the pics .
Larry
Posted: Mon Mar 07, 2011 11:21 am
by 72RoadRunnerGTX
Thanks for posting those pictures Larry, interesting, can't say I've seen any like that on these cars for sure. The way the parts book describes it, the support should be on all other 8 cylinder motors as well. Can't find the clip for it on my very original 318 either. Is that a wire loom wrap on the front of that cover?
Posted: Mon Mar 07, 2011 11:50 am
by Moparlar
It is a wire loom wrap on the front. I also found a set of valve covers like the ones you have on your car. I am not sure if this is a part year only thing or not. My 6 pack car did not have an engine in it when I got it. I will have to look for the pics and video of the 72 red 6 pack charger that was at Slobes to see if it had it or not.
I am also going to check all my parts books from different dates to see if it was added or removed sometime in the model year. This does happen as later parts books do not show 6 pack parts available in 72. I believe I have a August 71 dated book a December 71 dated book and an April 72 dated book. I just have to find them.
Larry
Posted: Mon Mar 07, 2011 1:23 pm
by 72RoadRunnerGTX
A couple original 72' reference shots I have. The six-pack may be the Charger you are talking about. Vapor lines appear to be draped over the cover in both pictures.
Posted: Mon Mar 07, 2011 2:16 pm
by Moparlar
I have seen my fair share of cars with the tab on the valve cover but the support missing, Probably 1 of those pieces that gets pulled off and never got back on.
