Help with Rad Question
moparmike
Post by moparmike » Mon Oct 25, 2010 9:01 pm
Hello all hope somebody has an answer for me.....I have replaced my 318 with a 440 and I want to replace my rad....I found one for sale and the model is 3574601 which is from 1972 I believe I think it came from an Imperial. My car has air does anyone know if this rad will work for my application the guy that owns it lives a few hours away so I can`t look at it and he has no pic`s but says it is a 3 core rad from a 440 car. My 440 is from 1967 and it is now in my 72 SSP. I have all the big block brackets and pulleys for air conditioning. Any help would be appreciated. :help:
SureGrip
Re: Help with Rad Question
Post by SureGrip » Mon Oct 25, 2010 10:31 pm
It 'should' work as long as the inlet and outlet ports on the rad match your water pump housing outlet...and that it is a 26", 3-core.
That's just from my memory, others may have more accurate input.
Post by rr6pak » Tue Oct 26, 2010 10:27 pm
According to the part number:
1972, 28" radiator, 440, auto, HVAC-All (meaning both with or without A/C), and specific to the Imperial. :D
Also, a three row? I thought that A/C cars should be a four row rad, not for sure.
quapman
Post by quapman » Wed Oct 27, 2010 6:32 am
There were no factory 4-row rads that I've ever encountered.
As long as the upper neck is on the pass. side and the lower neck is driver's side, and it's 26", you should be OK.
You may have to modify the pass. bracket to clear the frame rail, but it's an easy fix with a saw or grinder.
Post by moparite » Wed Oct 27, 2010 8:15 am
I'd stay away from used rads. You don't know the history or the condition. It might not last if you do get it. Get a new one and save yourself the headache. If you decide to get it does the guy have the air shroud?
moparmike
Post by moparmike » Wed Oct 27, 2010 6:54 pm
Yes he has the fan shroud, I have 2 rads that are in great shape but they vent in the wrong places basically because of the small block that I took out. I might bite the bullet and get a new one BOY parts are becoming non existend for our cars I guess that is why everyone wants big $$$$ for parts.
Post by rr6pak » Wed Oct 27, 2010 8:20 pm
Glen Ray has radiators but be prepared to spend $$$$, FYI
moparmike
Post by moparmike » Wed Oct 27, 2010 9:19 pm
At this point my desire to take her out for a ride is greater than the money its going to cost me for a rad ...........Man what a difference
Post by 71440 gtx » Fri Aug 10, 2012 8:17 am
3474601 1972 C 28 440 AUTO ALL IMPERIAL
3474602 1972 C 26 400 440 AUTO A/C POL/TAXI
3474605 1972 C 26 400 440 AUTO A/C
3474607 1972 C 22 400 440 AUTO HTR
3574611 1972 B 26 400 440 AUTO A/C
3574612 1972 B 26 400 440 AUTO A/C
3574613 1972 B 26 400 440 MAUL BOTH
i nave the 3574611 1972 B rad for my 71gtx and is 3 in row not 4
My Cars: 71 roadrunner
Post by dangina » Fri Aug 10, 2012 8:31 am
did our cars ever come with a 22" rad?
Post by 71440 gtx » Fri Aug 10, 2012 12:10 pm
dangina wrote:did our cars ever come with a 22" rad?
yes
Re: 1972 440 22" Radiator
« Reply #3 on Jan 29, 2012, 7:55pm »
all 7172 440 4bbl auto with 3-23 no ac 22 rad same as 318 340 383 400
all 71-72 440 4bbl auto with 3.23 ac 26 rad 318 340 383 400
71-72 440 4bbl auto with 3.55 and up 26 rad 340 383 400
71 440 6bbl or 4bbl auto with 410 dana 26 rad
71 440 6bbl or 4bbl 4 speed came with 3.54 dana or 410dana 60 26 rad
all 66 -71 hemi cars auto or 4 speed came with a 26 rad
:D
gcoupe72
Post by gcoupe72 » Fri Aug 10, 2012 9:26 pm
Agreed, driving a few hours for a used rad. unless it's from a good friend, is quite a gamble!
The water pump housing was changed (around '73, I think) to put the hose on the opposite side.
If you can find one of those closer to home, you can use your small block radiator.
In the old days radiator shops would cut off the hose nipple, cover the hole,and move it wherever you wanted.
If you just need the bottom nipple moved(and they don't charge too much) I'd try it. It would let you use a radiator you've already got, and being on the bottom, would be almost invisible.
Now if you're Driving in stop and go traffic all the time in the summer, you'll eventually want a 3 or 4 row.
But if it's mostly highway use, or drag strip, the two row will be OK.
Now I'm also assuming that you've got 26" radiators, and they aren't plugged! :lol:
Gee, I just noticed how old this is, wonder what mike did?
Post by dangina » Sat Aug 11, 2012 9:05 pm
to add to this - I'm in the market for a new rad and this one is the one I have my eye on:
http://www.championradiators.com/page/474333583
I know others on moparts have had pretty good success with champion - have any of you guys used the american eagle brand of their rads? how was the fitment?
Diriccatiticka
Post by Diriccatiticka » Fri Aug 24, 2012 7:39 am
I have a cheap Silla 26" aluminum radiator in mine. Does the job and had been torture tested on several accounts. I see a lot of guys locally by me running Champion radiators and they love 'em. Supposed to be direct fit, and what I like about them over mine is they even weld the filler neck on (while mine is just crimped). I wish they were around when I bought mine!
'72 Road Runner
